How Much Timing????
Old Jan 14, 2007 | 02:20 PM
65fury's Avatar
Question How Much Timing????
okay, i know another timing question , but i just want to get it right, so basically i want to know how much timing should i advance the pump.
MODS done to engine as of now with stock turbo
-60lb springs and 4k rpm kit
-laser cut dvs
-4inch straight pipe
-12mm studs
-marine headgasket .10 over size
-valet switch
MODS when twins are built
-435 injectors
-5inch exhaust
-#4 fuel plate
sooo how much timing should i bump it?? thanks
jason
Old Jan 14, 2007 | 05:52 PM
Fueling around's Avatar
Start off with 16°
Are you running a stock plate with the GSK?
Old Jan 14, 2007 | 08:48 PM
65fury's Avatar
yes im going to be running the stock plate with the 4k gov springs, but when i put the twins on should i bump the timing more or go less??
Old Jan 14, 2007 | 09:04 PM
smknram's Avatar
why do you want to run a stock plate?
Old Jan 14, 2007 | 09:18 PM
TxDiesel007's Avatar
Grind that plate
to a 100 once u get the twins, even now just grind it to a 10 plate and enjoy ur stock turbo a bit more, The stock plate, as ive said before is not the best for running full forward,
now far as your timing goes, since 16.5 blew ur HG, id go 15.5. Mine has just been good to me i guess.. But since ur gettin a marine over, why not just go to 16.5-18?
Rick
Old Jan 14, 2007 | 09:36 PM
smknram's Avatar
i would go with a zero plate
Old Jan 14, 2007 | 11:09 PM
Any more than 16° and you'll loose too much low rpm power with the current mods. After the injectors you can decide about increasing timing.
A stock plate is good for ... well, stock. Add governor springs and peak hp jumps to around 3,000 rpm. Slide it forward and add to the problem.
Everyone has their own opinions on plate profiles. I think a #0 or #100 is too hot with governor springs. A #4 does trim the upper rpm fueling a bit, but still plenty hot. A #10 has a nice profile, but without injectors you have to slide it to get hp on a 160 or 180 pump.
Old Jan 14, 2007 | 11:38 PM
65fury's Avatar
sorry i didn't specify, i meant that i was going to run the #4 plate after i put the twins on, i wasn't sure if if putting the #4 plate on with out the twins would toast the turbo .
im not sure if that was meant toward me, but i never blew my head gasket but anyways, would 18 degrees of timing be a good thing or would that be pushing the limits on an un o-ringed head?? thanks for all the help guys.
jason
Old Jan 18, 2007 | 08:53 AM
ssigmon's Avatar
With small injctors i wouldnt run any more than 18* or like said before you will notice the loss of low end power. I pulled an entire season with stock thinckness marine head gasket and studs at 21* advance turning 4k every pull with 45# of boost and no issues (between 15-20 hooks) It wasnt until the last pull of the year when I already knew i was gonna tear it down and oring anyway that i blew it, but that was on purpose kinda. i bumped timing to 28* and was pushing 60#s boost when it blew
Scott
AlCorr
28
Nov 27, 2008 10:05 AM
goose2w1
Aug 15, 2007 10:09 PM
06dmc
Sep 7, 2006 09:47 AM
ssigmon
May 26, 2006 03:54 PM
redhornet
May 28, 2004 06:06 PM
