How much timing is too much?
Old May 25, 2006 | 09:50 AM
ssigmon's Avatar
You can see my mods in my sig, I am looking for a little more high RPM power and was curious if i could run any more advance with studs and a marine gasket without too much of a risk of blowing the head gasket. I was thinking maybe 20* what do you guys think?
Old May 25, 2006 | 10:10 AM
wana12v's Avatar
my friend is running 24* on his truck with stock bolts and a marine gasket. It has bd injectors, 191 dv and a stock charger. he made 390 hp on dunbars at diesel mania over the weekend. it hasent poped the head in over 50,000 miles. when i get some more fuel and a charger my timing will also be set that high. Another buddy runs 28* on a marine gasket and stock head bolts. and brian block actually recomended 28* for big horsepower. the marine motors run 22* so i would feel safe running 24* on a truck with marine gasket and studs as long as drive pressure is kept in check and your not making more than 50 psi on that killer b2 it should survive.1:1 is 45 with that charger.
Old May 25, 2006 | 01:03 PM
ssigmon's Avatar
Awesome, thanks......that is what i was hoping to hear!!!
Old May 26, 2006 | 11:41 AM
jkretzer's Avatar
stock HG prob about 16-17 is getting into trouble. i know of a n 800 hp ctd that only had 21 degrees. the more timing the more you need to keep the rpms up, lugging is hard on the pistons and bearings. josh
Old May 26, 2006 | 03:40 PM
v8440's Avatar
What could I get away with on mine? It's at 16.5 deg now. I have the stock headgasket and headbolts, an htb2-64 14 cm, and boost is at 42 pounds. I guess there's not much room left for more timing?
Old May 26, 2006 | 03:54 PM
Willy91's Avatar
I wouldn't itme it any higher until you get it studded, I'm runnin 28* right now with my setup.
dieselJon
Jan 3, 2011 08:18 PM
AlCorr
28
Nov 27, 2008 10:05 AM
jjrightmire1973
Nov 20, 2008 08:20 AM
goose2w1
Aug 15, 2007 10:09 PM
03CumminZ4X4
Jan 16, 2006 10:11 AM
