how to get rid of valve noise in my boost gauge?
Old Mar 27, 2003 | 10:07 PM
j's Avatar
j
it has been making noise since it was first installed and i'm finally getting tired of the "whiring" sound as i accelerate. i've been told before that this is not too un-common to get lifter/valve noise fluttering up through the boost gauge tube. anyone have a quick fix?
Old Mar 27, 2003 | 10:25 PM
Mexstan's Avatar
Re:how to get rid of valve noise in my boost gauge?
You could try installing an oriface. There are various ways to do this. One way is to temporarily remove one of the brass pipe fittings near the engine. This fitting at a guess will have a 3/16 ID. Plug the hole with an aluminium rivet, solder or whatever. Then drill a really small hole thru that plug. You may have to experiment, but by small I mean less than 1/16&quot;. Probably into the small numbers such as a #60 drill.<br>Another way is to install an adjustable valve. Close the valve and then open it in small increments until the boost gauge just starts to work. Lock it in that position.<br>Let us know if this works<br>
Old Mar 27, 2003 | 11:54 PM
KATOOM's Avatar
Cut the small boost plastis hose and get some small rubber hose to fill the gap. I hear it is supposed to stop the vibs from climbing the plastic tube and into the gauge.
Old Mar 28, 2003 | 06:05 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Did you use the Plug in the block for your boost pickup?<br>If so I've heard/read that is a common complaint.<br>I tapped the intake horn, no noise yet.
Old Mar 28, 2003 | 06:37 AM
Smokee's Avatar
I also used the intake horn. No noise...at least, none that I can hear over the engine and the wind.
Old Mar 28, 2003 | 10:27 AM
j's Avatar
j
i may try the rubber hose trick first, but yeah i used the plug in the intake/block. i'll try theintake horn though if that doesnt work. it isn't real annoying, but after a long drive it can be a little bothersome. thanks all for the advice!!
Old Mar 30, 2003 | 12:37 AM
KATOOM's Avatar
I'm pluged into the block also and I dont get any noise. Maybe it has something to do with how the tube is routed? I also read that taping into the air horn doesnt give a true reading. Dont really know.
Old Mar 30, 2003 | 08:24 AM
NWDave's Avatar
Like Katoom, I'm coming out of the block and haven't had any noise from the boost gauge or associated peripheries.<br><br>~Dave
Old Apr 1, 2003 | 10:08 PM
j's Avatar
j
well the truck is at the *******, so i'll have to wait to fix it. tranny goin out already.
0524VHO
Jun 6, 2008 07:50 AM
bowhunter96
Jun 15, 2004 06:09 AM
chrismez
Oct 18, 2003 06:02 AM
99 cummins
May 24, 2003 12:27 PM
