How can I get to about 450 HP?
I only have experience with what I run on my truck, which is a factory lift pump mounted on the frame and Holley Blue fuel pump mounted near the fuel tank. The holley feeds the stock pump and from there to the fuel filter housing. It supports what I run for injectors and has been on my truck for about 3yrs without issue.
Brett
How did you wire the Holley Blue fuel pump ?
running the same fuel supply setup mounted to the frame by the xfer case feeding the factory LP...works great w/23psi of fuel filtered to 2micron.
Totallyrad
07-19-2011 07:41 AM
StakeMan
28
07-16-2003 12:15 AM
