Hooking A Fuel Guage To FASS System
Old Nov 29, 2007 | 12:08 AM
EverydayDiesel's Avatar
I know theres a port but what adapter do I need to hook up my edge fuel pressure sender to the FASS fuel port?
Old Nov 29, 2007 | 10:42 AM
someones gotta have a fass and an edge ....
do i extend the wires for the fuel pressure sensor all the way back to the fass or is there some kind of T that i can buy for it up front?
Old Nov 29, 2007 | 10:44 AM
fade94's Avatar
I put mine about 12" from my VP in the feed line from the FASS. I wanted to know what my VP was getting. Used a "T" fitting and needle valve.
Old Nov 29, 2007 | 10:47 AM
where did you get the 3/8 press fit T? what size is the pressure sensor fitting?
Old Nov 29, 2007 | 10:57 AM
fade94's Avatar
I got a barbed fitting from Home Depot. The blue line worked like a charm. I put clamps on just in case. The fitting had barbes on the ends and a compression fitting on the other. Come on over. We'll git er done.
Old Nov 29, 2007 | 11:01 AM
you wouldnt happen to have a part number would you, im fixing to run to home depot now and that would probably speed up the searching.
Thanks!
Old Nov 29, 2007 | 12:14 PM
fade94's Avatar
I sure don't. I just took a small piece of my blue line with me and got one that it fit and also had the compression fitting.
Timberman
Dec 15, 2006 09:12 PM
IsItFast
Jan 28, 2006 03:13 PM
BCarmicle
13
Nov 7, 2005 04:20 PM
Ian
Aug 17, 2005 07:38 AM
