High flow banjo bolt install
Old Nov 17, 2002 | 08:25 PM
BFC's Avatar
BFC
Re:High flow banjo bolt install
Maybe one more thing. Be carefull tightening the new banjo's, since they have larger holes, they are weeker than stock ones. They are not as resistant to over torquing. No big deal just be carefull or use a torque wrench if you have one.<br><br>Glenn
Old Nov 17, 2002 | 08:26 PM
PapaSmurf's Avatar
Hello<br> I installed a few of the rays banjo bolts in CTd now and I have not had a problem with any of them getting started.<br> I installed new seals (2) per banjo bolt to prevent fuel leaks as well as air leaks into the fuel system.<br><br>All I did was cycle the trucks twice and fire them up. I did not need to touch the throttle pedal.<br><br>I did not leak out fuel all over the place, very little fuel loss.<br>Hope this helps. It is a very simple install, but feel free to PM if you feel the need.<br>See Ya<br>Chris
Old Nov 18, 2002 | 07:17 AM
NWDave's Avatar
[quote author=Ascraeus link=board=7;threadid=7166;start=0#68533 date=1037624955]
Thanks, everyone! Snowed today, won't do this until it's above 40F. :P
A stupid question. : I assume that &quot;cracking the injectors&quot; means loosening the six big injector line bolts on the outside of the head, right? Or does it mean taking the valve cover off and carefully backing the line out of the injector itself?
Ascraeus
[/quote]
Well, tell you what. You can remove the valve cover but it won't do what you're after. I'll prefer to crack the #1 injector line (nearest the radiator) first, when I do mine next weekend (But maybe I'll get lucky and Papa Smurf will drop by and do 'em for me). Wait until above 40? I'd never get anything done if I did that. Installed my backup lights in 48 degrees but with slantwise rain and a few gusts of 45 knots. I know, it was uphill both ways.
~Dave
Old Nov 18, 2002 | 07:50 AM
dodgeman01's Avatar
torque wrench whats that? we don't need no stinkin torque wrenches.
Old Nov 18, 2002 | 08:14 AM
Shovelhead's Avatar
Administrator / Scooter Bum
[quote author=dodgeman01 link=board=7;threadid=7166;start=0#68548 date=1037627418]<br>torque wrench whats that? we don't need no stinkin torque wrenches. <br>[/quote]<br><br>When I replaced mine, I didn't use my torque wrench.<br>I used Jetpilot's torque measurment.........&quot;GNT&quot;<br>&quot;Good N Tight&quot; no leaks....no broken bolts. 8)
Old Nov 18, 2002 | 10:30 AM
BigBlue's Avatar
Just tighten them down snug. And have fun. I've replaced all but one on mine and that is the biggest PIA in the world. It did bring FP up a little though.
Old Nov 18, 2002 | 04:40 PM
TPilaske's Avatar
[quote author=BigBlue link=board=7;threadid=7166;start=0#68636 date=1037637046]<br>Just tighten them down snug. And have fun. I've replaced all but one on mine and that is the biggest PIA in the world. It did bring FP up a little though.<br>[/quote]<br><br>awww c'mon blue, they weren't that hard! which one haven't you replaced yet?? ;D
Old Nov 18, 2002 | 10:58 PM
Edward's Avatar
Banjo bolts who needs them? I got rid of mine and now have the same diameter fuel line from the tank to the VP44 including the fittings.
Old Nov 19, 2002 | 03:28 PM
BigBlue's Avatar
[quote author=TPilaske link=board=7;threadid=7166;start=0#68819 date=1037659215]<br><br>awww c'mon blue, they weren't that hard! which one haven't you replaced yet?? ;D<br>[/quote]<br><br>The one on the bottom of the fuel filter canister. I got the one on the VP44(FP gauge hooked up here), the one on the back of the fuel filter canister, and the two on the lift pump itself. That leaves the one on the bottom of the canister. I may do that one here in just a bit if I get REALLY bored.
Old Nov 19, 2002 | 03:53 PM
BigBlue's Avatar
I got REALLY bored. ;D
Old Nov 19, 2002 | 10:16 PM
PapaSmurf's Avatar
NWDave<br> Sorry no traveling for me till I get my chores done around the yard. As per guideance from my other half. ;D ;D <br><br> The only problem I had was getting my arms where they needed to go to get the job done. Both of my forearms looked like I got tangled up in barb wire by the time I was done.<br> Picture this : Bright sun shine, Blue sky, about 75 degrees. Me in a T shirt and shorts with a cold Coors Lite (waiting for me to get done of course) : 8) ;D <br>See Ya<br>Chris
Old Nov 20, 2002 | 11:06 AM
BigBlue's Avatar
[quote author=Papa Smurf (CRuD) link=board=7;threadid=7166;start=0#69728 date=1037765812]<br>NWDave<br> Picture this : Bright sun shine, Blue sky, about 75 degrees. Me in a T shirt and shorts with a cold Coors Lite (waiting for me to get done of course) : 8) ;D <br>See Ya<br>Chris <br>[/quote]<br><br>Do we have to? Makes me kinda to think about it.
sammy340
May 3, 2005 07:44 PM
hntnbo
Feb 21, 2004 10:40 PM
w4xtc
13
Jun 6, 2003 03:43 PM
Dodgezilla
Mar 9, 2003 06:42 AM
