Hi-flow banjo bolt question....
Old Mar 8, 2003 | 05:32 PM
Dodgezilla's Avatar
I just got a set from Wildcat diesel and I have one question. Where does the fifth one go? I replaced the two on the fuel filter canister and the two on the pusher pump. The one on the lift pump is shorter than these and it already had the large holes. Does this last one go on the back of the engine where the return line is or is there another one I am missing??<br>
Old Mar 8, 2003 | 05:38 PM
Scotty's Avatar
Top's Younger Twin
Re:Hi-flow banjo bolt question....
I do believe it goes on the injector pump.
Old Mar 8, 2003 | 05:43 PM
BigBlue's Avatar
Yeah. It replaces the one that goes in the injection pump with the Schrader test valve on it. Usually this one is tapped to allow a FP gauge to be hooked up to it.
Old Mar 8, 2003 | 06:38 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I got the 5 piece set for mine too and found out the one for the Injection Pump is shorter than the rest. Could only change 4.<br>I think the later years used all the same size bolts.
Old Mar 8, 2003 | 07:12 PM
Dodgezilla's Avatar
Alright. I was gonna try to see if I could make it work in the injector pump but decided against it when I compared the size of the holes and they were the same. I guess I just have a spare.
Old Mar 9, 2003 | 01:10 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Ed, Dodzilla, and anyone else with a 98.5:<br><br>Really, the injection pump banjo was shorter than the rest? Did you try the new high flow bolt to see if it would go all the way in, and not bottom out anywhere?<br><br>Need more input ;D<br><br>Dodgzilla, if the existing bolt already had the same size ports as the new one you got from me, drop me a PM with your real name. I'll issue the refund ASAP. No point in you paying for something you can't use. <br><br>Rod
Old Mar 9, 2003 | 06:42 AM
Dodgezilla's Avatar
Rod, you have a PM.....
motochamp250
15
Jul 29, 2008 10:40 AM
arcc
15
Feb 16, 2005 12:52 PM
barracuda
Jun 18, 2003 11:50 PM
w4xtc
13
Jun 6, 2003 03:43 PM
14
Nov 20, 2002 11:06 AM
