!!!HELP!!!South Bend on the cheap???
Old May 5, 2003 | 09:09 PM
BigBlock's Avatar
Hi everyone,
Well my predictions were right, my stock clutch didn't have a prayer. It is now starting to slip pretty bad. I was just wondering if anyone had a slightly used SB Clutch, preferably a Con FE(twins in sort of near future). But beggars can't be choosers, so any help at all . Also does anyone know about the TST clutch capable of holding up to 1000lb-ft?
Thanks,
Chris
Old May 5, 2003 | 10:23 PM
Got Smoke?'s Avatar
Re:!!!HELP!!!South Bend on the cheap???
[quote author=BigBlock link=board=7;threadid=14389;start=0#135218 date=1052186965]<br>Hi everyone,<br> Well my predictions were right, my stock clutch didn't have a prayer. It is now starting to slip pretty bad. I was just wondering if anyone had a slightly used SB Clutch, preferably a Con FE(twins in sort of near future). But beggars can't be choosers, so any help at all . Also does anyone know about the TST clutch capable of holding up to 1000lb-ft?<br> Thanks,<br> Chris<br>[/quote]<br><br>Would advise against a TST clutch from personal experience :'( :'( :'( <br><br>Don't even consider it if you haul trailers (it hauls ok, but backing is a &amp;*(#$!!)
Old May 5, 2003 | 10:35 PM
HeberRam's Avatar
Chris...One thing you don't want is someone's used clutch! To do it right, you need a freshly re-surfaced flywheel, new pressure plate, release bearing etc. This is something you don't want to do time and again! Bite the bullet and purchase a new South Bend Clutch. Would you put used oil in your truck? I don't think so.<br><br>Steve
Old May 5, 2003 | 10:46 PM
TxDieselKid's Avatar
Piers sells them cheap, and so does LPD.
Old May 6, 2003 | 08:54 AM
BigBlock's Avatar
Hi,<br> I would love to buy a new one even if it was stretching the ol' budget. But bottom line I can only afford about $450-$500 max. I don't want to make the same mistake I made before and buy a $400 stocker or a lower level SB, only to have it shredded by the Power I will be adding. We use used clutches in VW rebuilds alot. Granted its VW, but I figured a good used clutch would work work with a flywheel resurfacing. Thats why I asked.<br><br>Thanks
hawkeye759
Jul 29, 2011 10:18 PM
diggity dodge
Jul 25, 2007 12:36 PM
greenworks
Jun 26, 2007 09:48 PM
SmokinDodge12V
25
Apr 27, 2007 04:02 PM
presovtr
Dec 3, 2006 01:27 PM
