South Bend Clutch help
Old Feb 26, 2011 | 11:59 PM
hawkeye759's Avatar
Its beyond time for me to replace my oem G56 DMF and clutch assembly (150K). I have read through several posts on converting to the SB SMF clutches, but have become confused on which one I need for daily driving and occasional <15K towing.
Please help simplify;
Which South Bend Clutch do I need and why?
Old Feb 27, 2011 | 07:33 AM
jasonh's Avatar
I would call Peter @ SouthBend and ask him. Got a DD from them earlier this year and they were great answering my questions.
Old Feb 27, 2011 | 08:45 PM
rockcrawler304's Avatar
G56-OFEK would be my choice for a SB clutch.
It's good for 450 hp, 900 ft. lbs. torque and is a single disc.
Old Feb 28, 2011 | 10:21 AM
hawkeye759's Avatar
I am also looking at the Perfection clutch P/N NNC MU521791SK available at NAPA and Advance auto parts. Seems like a way less expensive way to go and it has some good reviews.
Any suggestions?
Old Mar 1, 2011 | 07:09 PM
railroaderone's Avatar
I installed a south bend clutch 3250 in my truck earlier this year and peter was a great help. Ive towed with my jr on performance with two f350 powersucks loaded on trailer and never been able to slipp the clutch . Call peter and see what he recomends
Old Mar 1, 2011 | 07:34 PM
Reelay's Avatar
Just got my truck back today from the shop. I had a G56-OK clutch installed. I tow a fifth wheel with my truck {12,500#}with the stock clutch that was in it, it started to slip when pulling a hill with any grade to it. I was told that the new clutch would solve the problem. This new clutch is a single disc. I got a new fly wheel, hydrallics, throw out bearing, and pressure plate. I also had them change out the rear seal and install a new shift boot. I haven't towed with it yet. That will happen on March 10th.
To my amazement the old clutch didn't look that bad but under a load it slipped. This clutch I had put in is not a radical clutch but one that will be fine for towing and driving. No noise coming from it at all just a lower release point. I paid $1800.00 for the job. With a 12/12 warranty on parts and labor. So far so good but I have only put maybe 75 miles on it. The proof will be in the pudding. Hope this helps you out in deciding.
Old Mar 9, 2011 | 06:49 PM
BLACKBEAR's Avatar
Smile
Go to south bend and tell them what you want your clutch to do and they will help you out and they send a new fly wheel and all parts need.
Old Mar 9, 2011 | 09:23 PM
Rod_Montana's Avatar
Originally Posted by Reelay
Just got my truck back today from the shop. I had a G56-OK clutch installed. I tow a fifth wheel with my truck {12,500#}with the stock clutch I paid $1800.00 for the job. With a 12/12 warranty on parts and labor. So far so good but I have only put maybe 75 miles on it. The proof will be in the pudding. Hope this helps you out in deciding.
Thanks for that. I looked up the "O" type clutch and this may be a decent selection for me as well.
Looking forward to your tow reports. I'm somewhat fanatical about letting out the clutch with engine at idle, and then applying fuel. Hate grabby clutches.
Tow lighter (6k) and moderate (9k).
Old Mar 9, 2011 | 10:28 PM
2500's Avatar
recently installed a new Sachs ceramic button clutch with a lifetime warranty ... purchased from Oriellys auto.... price was substantially cheaper than anything else I found.
very happy with performance... zero slip
Any suggestions?
Old Jul 29, 2011 | 07:32 AM
Reelay's Avatar
Pulled my trailer back to Missouri from Oregon and back. The only problem I had was a clatter when in reverse. It would bounce really hard at any small incline. I called South Bend and they said to put it in four wheel drive low when backing up {don't know what the two wheel drive 6 speed guys do}. As of yet I have not tried this. Reason the problem occured was because of the 373 gear ratio so putting it in 4 low should help out the ratio. I will update again after trying this suggestion.
Old Jul 29, 2011 | 10:18 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
250k miles of doing that and no ill effects makes backing a trailer a joy and with a hub kit its even easier
greenworks
Jun 26, 2007 09:48 PM
biglar
Nov 20, 2006 10:08 PM
J.R. Adkins
19
Apr 15, 2003 10:38 PM
29
Jan 21, 2003 10:23 PM
