Guages - why all 3?
Old May 11, 2005 | 08:43 PM
Ian's Avatar
Ian
Guages - why all 3?
I understand the fuel pressure guage, but why the EGT and Boost? I won't be doing a lot of heavy long haul towing, so would the EGT be necissary? Boost...no idea why i would need a guage for that (not informed).
Thanks!
Old May 11, 2005 | 09:26 PM
caleb c.'s Avatar
EGT is mandatory,they can get hotter than you think even unloaded.Boost is good to have to see if you have a bad IC boot or clogged air filter.The 2 work hand in hand.They can tell you a lot about the state of your engine.I wouldn't go without any of them.
Old May 11, 2005 | 09:34 PM
12valve@heart's Avatar
The Pyro and Boost are necessary if you change that "stock (for now)" in your signature. Since you said "for now", I'd guess that you're already thinking of mods so getting the gauges now will let you establish a nice baseline so that when (not if) you start modifying, you know what's changing. Since you have an automatic, a Trans. Temp is another good gauge to have if you do any towing.
Stick around and the bombing bug will get you sooner or later.
Old May 11, 2005 | 09:40 PM
Ian's Avatar
Ian
awesome, thanks guys! I really appreciate the feed back!
Old May 11, 2005 | 11:19 PM
jimjawz's Avatar
I get bit every time I drive my Hay-haulin, Cow-tippin, Mud-slingin, Ford-killin, Tire-burn Cummins Turbo Diesel !!!
P.s Did I mention that I love my big , black Oil burner.
Old May 12, 2005 | 02:58 PM
HOHN's Avatar
Boost isn't really necessary, as everything you'd want it for you can pretty much tell from the EGT.
However, if you are going to approach the limits of your turbo, you want boost so you know if you're about to grenade it or not.
jlh
Old May 14, 2005 | 04:24 PM
rebal's Avatar
I would use all 3. last year I was going over the grapevine and my egts started to go up fast looked over to see boost was at 5 psi. pulled over and found a turbo hose had popped .I could of burned the old girl up if not for the gauges. cheep insurance
Old May 14, 2005 | 04:44 PM
mr T's Avatar
pyro is the most important one...it will tell u the majority of info....boost is just a secondary peace of info to help u determine where the high egts are comign from so u better understand whats happening in the motor under load, high vs low rpm etc and then u'll know how to controol egts better....with pyro alone ur kinda guessing why ur egts might be high
Old May 14, 2005 | 05:38 PM
Shovelhead's Avatar
Administrator / Scooter Bum
If three are good, four are more better.
Old May 14, 2005 | 11:03 PM
James Lucas's Avatar
AMEN!
Old May 15, 2005 | 08:24 AM
Mopar1973man's Avatar
Yeah ... I agree too... But some of us don't have a auto trans... Nice setup Shovelhead!
Out here in the mountain I can be climb the forestry roads without trying I can get the pyro up to 1000-1100*F and without a load!
The other thing everyone forgot about is the pyro is important to let the turbo cool down properly. I try to get mine under 300*F before shutdown. I've seen a few times where I come back to the truck and seen the pyro climbing back up to 400*F again....
Boost gives you a good indication of how good the turbo is working including the wastegate and boots (leakage).
Fuel Pressure is a VERY important guage... Without good PSI your VP44 is toast! Kinda like mine right now... I wish I would have got the guages sooner!
I still like the white face Dipricol's...
freight train
May 28, 2010 02:37 PM
DWalts
Jun 2, 2008 08:46 PM
sgrooms
21
Apr 8, 2008 11:17 AM
gerry
Dec 30, 2005 01:46 AM
y-knot
13
Sep 25, 2003 04:40 PM
