gear swap
Old Oct 9, 2006 | 10:36 PM
24valver's Avatar
gear swap
I want to swap out my 4:10s for 3:55. Is this a stright up swap or do you have to change anything else???
Old Oct 9, 2006 | 11:23 PM
jefe4x4's Avatar
24valver,
I believe the break is above 4.10:1 on the carrier. So, 4.10/3.54 same carrier. You're in luck. Just ring gear and pinion change. I assume you have a Dana 80. You need more info in your sig. I think it's the best overall ratio for the 24V Cummins/ 6 speed NV5600. At 55 mph i'm turning 1600 rpm, right on peak torque. Freeway speeds are at 1900-2100 rpm, right in the 'sweet' range. Hauling my 16,000 lbs. of TC/T/JP/Trlr i get 15mpg at 57 mph.
regards, as always, jefe
Old Oct 10, 2006 | 02:39 PM
STACKED's Avatar
im looking for 4.10 or even some 3.73 for my truck, pulling a 35 foot camper with 3.55 gears and 315 tires, it dont like it.
Old Oct 10, 2006 | 02:48 PM
rustyshakelford's Avatar
is there a swap brewing out here?
brett
Old Oct 10, 2006 | 03:32 PM
blackdiesel's Avatar
Registered
i think they are different carriers. and 2nd gens dont have stock (notice i say stock) 3.73 gear sets.
Old Oct 10, 2006 | 05:28 PM
24valver's Avatar
I would swap mine out but if i were to take them out in my driveway i dont know if i could put them back in. I could do it but i wouldnt want to screw any thing up.
Old Oct 10, 2006 | 07:30 PM
Registered
if you do end up changing carriers, you'd have to do your backlash and all that stuff. Not the average lay-under-your-truck-in-the-drive-way job. got to have a couple special tools. (to do it right)
Old Oct 10, 2006 | 11:09 PM
24valver's Avatar
there is a good garage i would trust around here to do it for me. Gears isnt something i would want to mess with
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
CAPTDASH
Jan 21, 2004 01:47 PM
joel
May 4, 2003 07:03 PM
Wilber1
Dec 9, 2002 01:07 AM
