Gauges on order
Gauges on order
I am just before ordering my Isspro gauges from DieselManor.com I am getting their combo with the pillar mount (pyro, trans, boost) I am ordering the fuel pressure gauge also. I am not ordering the isolator. I will just pick up a needle valve when they get here. Does the FP gauge come with everything I will need to install it? Any extra parts?? I am also ordering the steering mount. Which gauge should I put in the steering mount or does it matter??? Thanks
Thats a toss up. If you tow a lot I would consider putting the tans. temp gauge on the steering mount. If not I would go with the fp gauge. From what I can tell you dont have any reason to worry about egt's right now, and the best use for the boost gauge on a stock truck is to see if you are getting enough air to the engine. When I first got my truck it smoked a little bit which I thought was normal until I started reading about the 24 valves. When I got my boost gauge hooked up I noticed I was only getting about 13 pounds of boost and later found out that my lower intercooler boot was leaking. Man that is an expensive little piece of rubber
Kman9090
29
12-06-2007 06:43 PM
jmccart
08-02-2007 12:35 AM
coontz0473
17
09-22-2006 03:52 PM
dealseeker
15
12-17-2002 06:43 AM
