Gauges on order
I am just before ordering my Isspro gauges from DieselManor.com I am getting their combo with the pillar mount (pyro, trans, boost) I am ordering the fuel pressure gauge also. I am not ordering the isolator. I will just pick up a needle valve when they get here. Does the FP gauge come with everything I will need to install it? Any extra parts?? I am also ordering the steering mount. Which gauge should I put in the steering mount or does it matter??? Thanks
Thats a toss up. If you tow a lot I would consider putting the tans. temp gauge on the steering mount. If not I would go with the fp gauge. From what I can tell you dont have any reason to worry about egt's right now, and the best use for the boost gauge on a stock truck is to see if you are getting enough air to the engine. When I first got my truck it smoked a little bit which I thought was normal until I started reading about the 24 valves. When I got my boost gauge hooked up I noticed I was only getting about 13 pounds of boost and later found out that my lower intercooler boot was leaking. Man that is an expensive little piece of rubber[laugh]
how do you tell if the intercooler boots are leaking?
