fuel plate?
Old May 24, 2004 | 08:33 AM
Lambo's Avatar
fuel plate?
Planning on adding a scotty air 2, 4 inch exhaust, and gauges. What plate can i go to before egts get out of hand. i want to be pushing the limit because i dont do much towing, thanks.
Old May 24, 2004 | 08:53 AM
rharveysr's Avatar
#10 plate!... This plate is so adjustable. You can install it in stock position..and if that dont work like you want because of heat..move it back about 15k. Also if you dont have the power you want and you have the other parts to handle it(trans,clutch,turbo,air system) you can slide it forward of stock.
Another little addition that works great with this plate is a set of 3k governor springs.
When I first started down the BOMB trail..I wish I had started with the #10 plate and spring. Then as my other parts changed..I could have just slide the plate a few thousands forward instead of having the replace the plate..
As you can see by my signature I have changed a few things..but the egts are workable..
Rick
Old May 24, 2004 | 09:37 AM
Lambo's Avatar
3k gsk
where will the engine govern out with 3k gsk? how much does it cost. What horsepower do you think i will be at with my 230 injectors, #10 plate, 4inch exhaust, 3k gsk and a scotty air 2? thanks
Old May 24, 2004 | 09:41 AM
infidel's Avatar
#10 rules! You will have about 350hp with your setup.
GSK kits here- http://www.piersdiesel.com/DodgeUSPrice.htm
Old May 24, 2004 | 09:58 AM
Lambo's Avatar
350hp
350 hp would be awesome will my turbo handle all that fuel? and if i dont tow will my stock clutch still go kapoot pretty quick?
Old May 24, 2004 | 10:54 AM
rharveysr's Avatar
That is the beauty of this plate... if you dont want to deal with a new clutch right now...slide it back from stock a little..and things should be fine.
Once the clutch is done...slide it forward a little. You may need to address the exhaust housing it keep things down..
My truck is a 215'd pump truck and the way I have the plate setup..I can see some heat(1400*) if I stay in it hard. But normal everyday driving empty...it works great and NO egt issues.
Rick
Old May 24, 2004 | 11:01 AM
Lambo's Avatar
clutch
where do you have your plate set (in regards to ahead, forward, stock.) and WILL my clutch hold at all with daily driving with the plate full forward. And what do i need to change my housing to?
Old May 24, 2004 | 11:55 AM
rharveysr's Avatar
My plate is 20k forward of stock. Will the clutch hold if the plate is full forward.. that depends on how you drive. If you like the jack rabbit stars..NO it wont hold..if you drive it like your not going anywhere and wouldnt know it if you got there..it should hold for a while.
I drove my truck with a #11 plate for a number of miles on a stock clutch. The only reason that I replaced it was because it was done to the rivets. It was wore out completely. Not from slipping..just use..
The exhaust housing is a simple change...I think there about $150 for the 16cm non wastegated and $177 for the 14cm non wastedgated(PDR prices)
The 3k GSk is anywhere from $125-$150 depends on where you buy.
Rick
Old May 24, 2004 | 01:01 PM
Lambo's Avatar
housing
which housiing do i want the 14 or the 16? also where will 3k gsk govern out at. and so if i am easy on letting out the clutch i should be fine for awhile. prolly doesnt matter cause i wont be able to resist dropping the clutch thanks
Old May 24, 2004 | 02:04 PM
rharveysr's Avatar
Dropping the clutch WILL speed up the replacement...but you would also be able to slip the clutch in 5th when you get on it...
How much more ponies do you plan on adding????
The 3k GSKs have made it possible for me to shift between 2800-3000 and still have plenty of fuel. If I remember correctly it will start to defuel around 2800+
Rick
Old May 24, 2004 | 02:23 PM
Lambo's Avatar
housing
Hey rick, how much was your pdr turbo? would i want a 16cm housing if that is all i switch? how do you like your clutch? does it realease good. i saw a post on here about the con ofe now releasing correctly
thanks
West Coast
Jul 1, 2007 02:32 PM
plow
Jul 20, 2005 08:40 PM
Rockcrawler
14
Jun 23, 2005 11:40 AM
banks twinram
Feb 5, 2005 10:38 AM
