Fuel mod question.
Old Jul 2, 2011 | 04:42 AM
Hotwheelbill's Avatar
Fuel mod question.
I have 200k miles on this 2000 ram2500. BHAF getting done today. And looking at 4" exhaust and a programmer later. In my head , I am thinking 350 to 400 hp at the most when "I'm done" (famous last words). Is the Airdog 150 for me?
Old Jul 2, 2011 | 05:29 PM
IanM's Avatar
Might be overkill, but better fuel makes for a happier truck. If this is for a 24v, and it has the stock lift/injection pump I would do it without hesitation. I'm rusty on my VP44's, but that might be a limiting factor as a stock VP may not be able to give out that much PSI...
Old Jul 6, 2011 | 02:50 PM
a&b guy's Avatar
the 150 air dog will do fine. Its 150gph still at 17 psi. It just a little over stock. VP's are extremely fragile when it comes to fuel. its better to leave room for improvement then to go "oh ****" when your pressure drops!
Old Jul 6, 2011 | 10:08 PM
Tate's Avatar
150 gph is more than enough. I've got a 95 gph on my 13mm p-pump, it still holds 20+ psi at WOT.
Old Jul 7, 2011 | 05:11 AM
wurkenman's Avatar
This si what you want. You will not regret it. Even sold right here on DTR.
http://www.dodge-diesel.org/9fubomelipus.html
Old Jul 7, 2011 | 11:40 AM
01blackspeeper's Avatar
how is the fuel boss for reliability
Old Jul 8, 2011 | 01:58 PM
Deezil's Avatar
100 is big enough for 400+HP
Old Jul 8, 2011 | 03:28 PM
Nick02Ram's Avatar
Fuel boss is, IMO, more reliable than an electric pump....it cant blow a fuse or burn up. I've had mine on for well over 2 years now with not a single issue. Only thing that can really go wrong is lose a belt, but it's rare.
Old Jul 9, 2011 | 08:07 AM
wurkenman's Avatar
If engine is turning you are pumping fuel. I did not even leave the stock pump on, just installed it as a stand alone.
Kenworth
Jul 15, 2008 04:18 PM
jmccart
Dec 19, 2007 12:49 AM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
14
Apr 23, 2007 06:46 PM
RAMV
Jul 14, 2004 12:08 PM
