Fog Lights??
Fog Lights??
Hello all.....
I have a 2001 Dodge SWB QC Auto and I didnt get foglights when I bought the truck new. While doing some maintenance stuff under the truck yesterday, I noticed two wires, one on each side near the front bumper with plugs on the ends. I was wondering if anyone knows if this is where the factory foglights are pluged in? I would like to add some aftermarket lights but I dont want to hook anything up unless I'm absolutely sure WHAT im hooking up, if that makes sense?
Happy Labor Day!
Happy Labor Day!
Most of these trucks are built with the same wiring harness, so I would say go for it. If your truck has the foglight switch integrated with the head light switch, you can probably hook it up. In that case, you'll need a fuse for the in cab fuse panel, a relay (or two) for the fusebox under the hood and two 35watt fog lights. If you don't have the integrated foglight switch, you're probably best off installing the foglights separately. JMHO, YMMV, not resposible if you burn your truck down.
brandon.
brandon.
mine did not have foglights either. i also had the wires with the plugs. i put in 2 6" hella's and cut the connectors off those wires and used them. they are for the foglights. i have pics of my truck in my photo gallery.
Yep, they are for foglights. My 1992 Spirit also had the correct wiring for factory lights, as specified for Canadian purchase. I had to swap front bumber covers, install a Canadian headlight switch, and plug in the relay and I had a Canadian issue front end!
Much better driving at night through deer infested territory!
I was looking closer at the plugs today, and the drivers side plug has a red and blue wire. This plug is located right next to the transmission cooler lines. The passenger side plug has a black and grey wire. But these two plugs appear to be different from one another.
I checked the owners manual and it looks like you turn the headlight switch on, then pull it out to turn the foglights on. I tried this, and I couldnt get the switch to pull out, so I guess I dont have the integrated foglight switch...
My luck...
My luck...
If the wiring is right, (which I would think that it is), it would just be a matter of getting the headlight switch with the integrated foglight switch. I would think you could get one at a salvage yard pretty cheap, or maybe even ebay.
I know NOTHING about this guy, but he is supposedly selling a complete OEM kit for the foglights with switch, wiring, lights and brackets. Looks interesting.
HERE is a link to the auction.
My luck...
My luck...
bullboy85
Dec 18, 2009 12:55 PM
fjbiker86
37
Dec 9, 2007 07:29 AM
patriot dodge
Nov 23, 2007 07:57 PM
Mcmopar
71
Feb 27, 2007 01:58 PM
msatow
Sep 27, 2006 07:32 PM
