exhaust wrap?
so bc847 are you saying that the temps will run hotter in the down pipe? and what kind of failure can i experience from having the hot gasses stay were the hot gasses are supposed to be? i know this wasnt your posting but maybe you can enlighten us. and also the wrap is not putting more fuel into my engine so were is this "extra heat" going to come from? isnt it better to keep the heat were its supposed to go and not heat up my engine bay? and the disclaimer im sure isnt reffering to diesels were the egts are way higher then most gas cars. and i forgot that in my previous post about the cool down time... that was after a wot run, cool down time is actually a slight bit better when normal driving.
- Compared to the uninsulated down-pipe, yes. Simply because you're loosing less heat through the metal of the down-pipe. If there's 900*F exhaust gases entering the down-pipe, those exhaust gas temperatures will be closer to 900*F exiting the insulated down-pipe compared to the uninsulated.
- Actually it is my post, but from a similar thread.
It's not that the wrap (insulation) itself that causes an issue. It's the fact that all metals exhibit strength/fatigue/corrosion characteristics that change with temperature (among other things). Take two like pieces of steel, both being placed under a like load and environment. Changing nothing else, raise the temperature of one. That piece will become physically weaker, and tend to corrode at a higher rate than the other.
See High temperature corrosion ~ http://en.wikipedia.org/wiki/Corrosi...ture_corrosion
See Factors that affect fatigue-life ~ http://en.wikipedia.org/wiki/Metal_f...t_fatigue-life
Insulating an exhaust component will have it run at a higher temperature as compared to the uninsulated. It will be weaker physically, and corrode at a faster pace.
- Nowhere. You're just not cooling what you have as much.
isn't it better to keep the heat were its supposed to go and not heat up my engine bay?
- Yes.
and the disclaimer I'm sure isn't referring to diesels were the egts are way higher then most gas cars.
- Infernal combustion engines is infernal combustion engines. The only difference in a diesel and gas engine is the fueling/ignition means else, iron is iron, steel is steel. Hot iron and steel will be weaker and corrode faster.
One BIG difference though is that most "Headers" are of thin-wall metal. As you know, our CTD's run cast-iron exhaust manifold, turbocharger exhaust housings, etc.
The thin/light metal will soak up heat and therefore rise to a higher temperature, at a much higher rate than the thick/heavy cast-iron all else being the same.
In that shade of light, the impact of insulation will have a much more profound effect with the thin metal in the short term.
- Yep, insulating the down-pipe should have zero effect on engine cool-down times (as measured at the EGT probe in the exhaust manifold, just prior to the turbocharger.
It's not that the wrap (insulation) itself that causes an issue. It's the fact that all metals exhibit strength/fatigue/corrosion characteristics that change with temperature (among other things). Take two like pieces of steel, both being placed under a like load and environment. Changing nothing else, raise the temperature of one. That piece will become physically weaker, and tend to corrode at a higher rate than the other. See High temperature corrosion ~ http://en.wikipedia.org/wiki/Corrosi...ture_corrosion
- Yes.
Insulating the exhaust manifold and turbocharger exhaust housing will contribute to more power available to the turbocharger's compressor. Again, as posted above, the heat of the exhaust gases is the power that drives the turbocharger's turbine.
- It may not register in the Seat-Of-The-Pants gage but it's there.
dieselcarpenter
Jul 12, 2013 09:45 AM
Dean Snow
Nov 30, 2009 04:07 PM
sheriffav8r
Apr 16, 2008 06:14 PM
trik396
Apr 19, 2006 09:21 PM
