jammer 3 black smoke
Old Jan 17, 2009 | 08:43 PM
dieselboy59's Avatar
Hi I just installed jammer 3 nozzles I have a j/with att. I hit 40 lbs of boost and only small amount of black smoke on level 5.I thought it would smoke worst with the stock turbo does this sound right.
Old Jan 21, 2009 | 06:56 PM
powermad's Avatar
the threes dont realy smoke all that much it could be the vp44 not being able to keep up with the fueling. do you have a fuel pressure guage?
Old Jan 21, 2009 | 09:23 PM
have a fuel gauge ok have a rasp transfer pump lots of fuel to the vp 44.I hit 40 lbs of boost with the stock turbo.Did you install your stage 4 s when you still had the stock turbo?
Old Jan 22, 2009 | 05:58 PM
powermad's Avatar
heck no i had the turbo on about 6 months after the edge box. i would strongly recommend getting a new turbo! 40psi is way high on a stock charger. do you have the hy-35 or hx-35? a lot of people i know notice less smoke with the hy. i had the hy and with a edge box on 5x5 it barely smoked at all because the spool was so fast. if your getting 40psi, have good fuel pressure and barely any smoke consider that a good thing that means your engine is running efficient. and if you want it to smoke disconnect the map sensor, by doing that it will fool your fuel system into thinking your truck is at 19psi and will fuel heavy but it mess's with your fueling curve so you loose power but it will lay out a huge cloud of smoke. cool for looks but ineffective. everything sounds fine with your set up but get a turbo ASAP!!
Old Jan 22, 2009 | 06:47 PM
Hi I have a hx35 .when i get the money iam going to get bd twins. I have my juice with att set to max of 35 psi .It does black smoke i thought it would smoke more than it does.
Old Jan 22, 2009 | 07:19 PM
powermad's Avatar
yea you wont get a lot of smoke with those i know from experience that the 4s smoke a lot... when you want them to.
Old Jan 22, 2009 | 07:50 PM
jd4440's Avatar
I have 3's and they did not smoke that much with my edge comp box had to try hard and had the intake sensor unplug got a little more smoke but when i installed in the tst and used comp for timing i can smoke on demand and way to much smoke but i really need a turbo
BuildingBoost
Mar 25, 2007 07:46 PM
xOmertAx
20
Feb 17, 2007 09:52 PM
BlackSheep5
Nov 27, 2006 07:52 PM
bensdad_canada
May 9, 2005 10:56 PM
dhe9
Nov 14, 2003 07:31 AM
