Sponsored by:
Sponsored by: CARiD
Exhaust wrap
Old Dec 30, 2005 | 06:28 AM
DetroitDiesel71's Avatar
From: Dayton, NJ (temporarily while In USCG on Staten Island)
Exhaust wrap
Morning all, just curious on thoughts about wrapping exhaust with fiberglass insulation tape, from the turbo/exhaust mainfold , the entire hot side of turbo and down pipe. We wrap the marine engines from the hot side to the point at which it exits the boat at bulkhead. Would this retain too much heat in turbo, or have no effect. Just wondering if anyone has done this.?
Stephen
Old Dec 30, 2005 | 01:00 PM
Mike D's Avatar
I think it would help with regards to spool up, plus it might keep thing a bit cooler under the hood, not a bad thing for folks running open air filters.
Old Dec 30, 2005 | 03:21 PM
BC847's Avatar
1st Generation Admin
To counter MikeD's points, It's my understanding that the insulation greatly accelerates corrosion of the pipes and such due to the higher than otherwise temps. This in fact may not be an issue with diesels as the exhaust is substantially cooler than a gasser.
Old Dec 30, 2005 | 03:32 PM
kandgo's Avatar
Moroso makes header wrap, I have had mine wraped from the turbo back to behind the cab for years, it will quiet it down and it will not hurt the turbo, if anything it will keep the heat away from the fire wall and cab and again it will quiet it down. Goodluck,,Rick
Old Dec 31, 2005 | 11:42 AM
rockwithjason's Avatar
I had header wrap on my F250 with a 390. It did keep the heat in but the headers only lasted a year or two. Now I don't know what gasser EGT's look like, so diesel may be ok with the added heat.
dieselcarpenter
Jul 12, 2013 09:45 AM
Dean Snow
Nov 30, 2009 04:07 PM
powermad
16
Jan 22, 2009 07:25 PM
sheriffav8r
Apr 16, 2008 06:14 PM
trik396
Apr 19, 2006 09:21 PM
