Engine noise?
Old Dec 19, 2004 | 08:07 PM
  #31
Hemi Cat's Avatar
Have you checked your valve adjustment lately?
Old Dec 19, 2004 | 08:21 PM
  #32
masonic-dodge's Avatar
I adjusted the valves when I put the valve springs on 4 weeks ago. The engine only makes the noise at hard throttle.
CRIS
Old Dec 19, 2004 | 09:39 PM
  #33
Hemi Cat's Avatar
You may have an exh pipe close to a frame or crossmember. Check the mounts too.
Old Dec 20, 2004 | 05:46 PM
  #34
Hemi
I just changed the injectors and still have that strange noise. It is not the sound of two things rubbing, I just don't know. I think I might readjust my valves this weekend, maybe that will do it
CRIS
Old Dec 20, 2004 | 05:52 PM
  #35
INJECTOR JACK's Avatar
Any luck finding your engine noise problem yet? Thinking also you may have air entering the system but then you would have hard starting as well.
Old Dec 20, 2004 | 05:56 PM
  #36
Jack
My truck starts better then any other car or truck I have ever owned I hate that I don't have any idea what that stinkin noise is
CRIS
Old Dec 20, 2004 | 06:26 PM
  #37
Geico266's Avatar
Originally posted by INJECTOR JACK
You advanced your timing right? It's probaly your head bolts popping off!
THAT was too funny!
Old Dec 20, 2004 | 06:28 PM
  #38
Geico266's Avatar
Chris, Anyone, is what you are hearing the injector pump? Are you talking about WOT and you let off the throttle alittle?
Old Dec 20, 2004 | 06:32 PM
  #39
Geico
You have got me Start again and say it slower please.
CRIS
Old Dec 20, 2004 | 08:00 PM
  #40
Geico266's Avatar
Re: Engine noise?
Originally posted by masonic-dodge
Sometimes I get a strange noise from my engine when I get on it hard. It sounds like a gasser when they spark knock does anyone have any idea what this might be? Other then that it runs great
Thanks for any help to come.
CRIS
When ... you .... have ..... the .... throttle .... peddle ....(foot peddle to the right) pressed ... to .... the .... floor. (WOT = wide open throttle) Is ...... what ..... you .... are ........ hearing ...... the....... injector ...... pump? (the pump that pushes fuel into the injectors, then into the cyliders based on the position and timing.)
Is that slow enough for you ???
Old Dec 20, 2004 | 08:14 PM
  #41
Geico
Thats slow enough for me! I don't know if it is the pump or not because I can't get my head under the hood at the same time I'm driving that is my problem. I know it is coming from under the hood but thats all I can say. It will not do it in park, only when driving. It will do it at WOT + almost WOT and like I said it sounds just like spark-Knocking in a gasser ( thats the only way to explain it) It could be the pump-But what part of the pump would be making that sound I just don't want to break anything!!!!!!!HELP
CRIS
Old Dec 20, 2004 | 08:21 PM
  #42
Geico266's Avatar
I have the same noise! I would like opinions on it also.
With all them GTO's you haven't figured out a way to drive from the engine compartment so you can see whats' going on under the hood? I Chevy man has to!
Old Dec 20, 2004 | 08:30 PM
  #43
I don't have to see under the hood of a GTO to know whats going on, its easy-part throttle=center carb Full throttle=all 3 carbs
CRIS
Smkn600CTD
May 22, 2012 07:21 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
richard
Jan 18, 2003 08:55 PM
Gregor
Dec 3, 2002 12:18 AM
rattle_rattle
Nov 24, 2002 08:10 PM
