edge drag comp
edge drag comp
Today I tapped the wire for my drag comp since I now have 101000 mi. At 96000 I had a new lift pump and injection pump installed. I went for a little ride never exceeding level 3 on the comp. Decided to see if it thru any codes and came up with P 1693 p 238 and p1475. Don't know what these are can anyone help. If it is my lift or injection pump I don't want to here from you!!! Just kidding. But I really hope that is not the case. Thanks for any help or replies.
Could someone explain the high voltage one to me. Know the high boost limit (Turnbuckle on turbo wastegate) Maybe not a good idea?What would be a good turbo to run with the drag comp. This little hy 35 isn't going to cut it. LOL
Jazz
Posted by Jazz_kt2000
"What would be a good turbo to run with the drag comp. This little hy 35 isn't going to cut it."
Turnbuckle is OK...just be aware you are getting more heat than help above 34-35 psi boost. With the Drag Comp and injectors you will have to watch EGT,s with any single turbo....and with the automatic, you will want/need quick spooling.
Your choices are limited to three, in my opinion...HTB2...PDR40...or a KSB-1. 1st and 3rd both seem to spool up equally well...and the B-1 moves the most usable air (10-15% more), but is more expensive.
RJ
RJ
Originally posted by jazz_kt2000
Unhooked battery cables and still have the codes any ideas how to get rid of them. Same three as before. Thanks in advance
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
rockjeep73
Mar 25, 2005 03:34 AM
MoreSmoke
Jan 7, 2004 09:40 PM
