edge comp with tapped pump
Old Mar 21, 2011 | 11:10 AM
diesel_man_85's Avatar
I have been running my edge comp without the pump tapped and I just barely tapped the pump about two weeks ago, and now when I turn to level 5 and get on it I can push about 38 to 39 pounds of boost. Is that much boost too much for a stock turbo.
Old Mar 21, 2011 | 04:17 PM
birddoctor's Avatar
No from what I've read on here, a stock turbo is godd to about 40 lbs or so.Your still good with that.
Old Mar 21, 2011 | 06:31 PM
Copenhagenjunkie's Avatar
There are many opinions on this one. Basically anything above 30-35 psi is just hot air, not very good. I have my waste gate set at 28-30 psi.
Old Mar 22, 2011 | 12:25 AM
So after 30 psi the intercooler just can't cool it fast enough or what
Old Mar 22, 2011 | 07:44 AM
nickg's Avatar
depending on which turbo you have
40 psi is way too much for a HY35,(hy found on 01-02 automatic trucks) identified by a hard metal line to the actuator.
at the higher psi the turbo is out side its efficency range and the exhaust drive pressure is higher than the boost its making, this helps drive
exhaust temps out of control easily. andthe turbo would be overspinning to achieve the higher boost numbers.
all that being said some people still push them way past accepted safe limits
fill out your sig so we can help better, (depending on your mods, you may be overfuelling you turbo)
Old Mar 22, 2011 | 01:21 PM
i dont know what turbo i got but its on an 02 manual transmission. from what i have been told is that the manual transmission trucks have a bigger turbo than the auto trans is that true i posted all my mods on my details idk if they will show up when i post this or not i dont know how to work this site yet
Old Mar 22, 2011 | 04:37 PM
Some really good info here:
http://www.dodgeram.org/tech/dsl/Facts/01ISBspecs.html
REDNECK-WELDING
20
Jun 19, 2007 06:16 PM
Timberman
Aug 23, 2006 12:26 PM
JD farmboy
May 21, 2006 01:04 PM
taken5875
Nov 28, 2005 12:19 AM
rockjeep73
Mar 25, 2005 03:34 AM
