Which Is The Easiest
Old Sep 17, 2008 | 04:00 PM
cowboy2526's Avatar
I am interested in knowing which one ya'll think would be the cheapest to bomb really good.
Old Sep 17, 2008 | 09:12 PM
TRQMAN's Avatar
which what?
Old Sep 17, 2008 | 09:23 PM
xtoyz17's Avatar
Which golf cart? I hear the gas ones are better. The electric ones have limited range and low power. EZGO is the better brand, twin cylinder engines versus the single cylinder like the yamaha golf carts.
Old Sep 17, 2008 | 09:41 PM
cowboy2526's Avatar
The trucks in my sig!
Old Sep 17, 2008 | 10:03 PM
EBunger's Avatar
Definitly the 01
Old Sep 17, 2008 | 10:13 PM
cowboy2526's Avatar
ok your the first one to say that what would make it easier?
Old Sep 17, 2008 | 10:22 PM
blackdiesel's Avatar
Registered
both computer controlled engines. both just plug and play. both have huge aftermarket injectors. the 07 has much better injector pump. and you can put dual cp3's on it. 01 you can p pump. just take your pick
Old Sep 17, 2008 | 10:32 PM
cowboy2526's Avatar
Ok i dont understand what p pump means i have limited experience and knowledge
Old Sep 18, 2008 | 12:04 PM
Flatbed24v's Avatar
the p pump is the machanical ip that is found on the 12v's. They put out lots of fuel.
Old Sep 18, 2008 | 12:09 PM
91rangerturbo's Avatar
I would say the 07 runs strong already. I would leave it alone. The 01 check into quad adrenaline or edge juice with attitude. Some bigger injectors, Nice turbo, clutch or tranny, etc.. That will wake the truck up alot.
Old Sep 18, 2008 | 12:40 PM
braxton357's Avatar
To "bomb really good"? It depends on what you mean by really good. If you go the route of a lot of 24v people, spend 10k maxing out a vp44 at <700hp then spend 5k or so again to change over to a p pump to make real power and rpms. Or spend half that and have more/streetable power with the commonrail. It's sad how easily those trucks can make big power.
Old Sep 18, 2008 | 01:16 PM
xtoyz17's Avatar
Ditto. I'm contemplating going common rail because with the money I spent a common rail makes stock, and the trans is built to hold it better to begin with.
Old Sep 19, 2008 | 03:38 AM
Tate's Avatar
07 will gain you much more for less than the VP truck will. You will need injectors and turbo and a box on the VP just to equal what a programmer does on the CR. Only real downside to the CR (besides all the electronics and the sound) is the lack of RPM, but the VP isn't any better in that department either.
cowboy2526
Sep 17, 2008 05:04 PM
Tommy93w350
Jul 7, 2006 01:35 PM
hotdram
Mar 7, 2006 10:11 AM
caleb c.
14
Apr 10, 2005 06:17 PM
CumminAtYa
28
Dec 11, 2003 08:42 AM
