Easiest Front Shock Replacement Procedure????
Old Jun 18, 2006 | 09:31 PM
Tommy93w350's Avatar
I can't find a front shock replacement procedure. Could someone tell me the easiest method or give a link.
Thanks
Old Jun 18, 2006 | 09:40 PM
nitrousn's Avatar
Remove both lower bolts. Right side remove air cleaner or tubes as needed. Remove the 3 bolts from the top shock bracket remove the shock and bracket and swap the shock and reinstall. On the left side things are tight. Remove the top nut first and then remove the top shock bracket 3 bolts and remove the bracket and then the shock. Reverse the operation to reassemble. Like i said tight on the top but everything does come out. Install the lower bolts.
Old Jun 18, 2006 | 09:52 PM
Sounds easy!! I thought the front end had to be jacked off the ground . Thanks
I bought Monroe Gas magnums, I hope I like them.
Old Jun 18, 2006 | 10:02 PM
Silverjay's Avatar
Depending on the width of the bottom of the shock you may have some problems. With my Bilsteins I had to either spread the bottom shackle or sand the paint off of the shocks where it slips into the shackle.
Old Jul 7, 2006 | 09:31 AM
getblown5.9's Avatar
will this work on the late 2nd gens with all the ABS crap located on the drivers side inner fender? looks way too tight to get a shock out from the top
Old Jul 7, 2006 | 12:14 PM
nitrousn's Avatar
Thats how i did mine and it has ABS....
Old Jul 7, 2006 | 12:39 PM
guess ill try it tonight since the truck is just sitting and not going anywhere...thanks
Old Jul 7, 2006 | 01:35 PM
BarryG's Avatar
I did mine as described above and it is a bit tight on the driver side but not really a problem
freight train
22
Mar 25, 2013 04:46 PM
1970dodge
Feb 13, 2009 08:38 PM
stumpjumper
Aug 21, 2007 07:14 AM
dixiedog
Jul 29, 2007 07:03 PM
docram
Nov 7, 2006 11:16 PM
