Difference in years for Edge Comp?
Old Oct 7, 2002 | 05:53 PM
CMN_NOT_STROKN's Avatar
Is there a difference in the Comp between years. Like from a 02 will it work in a 99?
Old Oct 7, 2002 | 08:21 PM
Scotty's Avatar
Top's Younger Twin
Re:Difference in years for Edge Comp?
[quote author=CMN_NOT_STROKN link=board=7;threadid=5647;start=0#49563 date=1034031224]<br>Is there a difference in the Comp between years. Like from a 02 will it work in a 99?<br>[/quote]<br><br>98.5 to 00' same<br>01' different<br>02' different again <br>
Old Oct 7, 2002 | 10:19 PM
So I should be able to purchase a used one that is coming off of a 02 and put it on my 99, right? Just want to make sure since I won't be able to return it and I wanna be able to USE it! ;D
Old Oct 7, 2002 | 11:13 PM
BigBlue's Avatar
I think you have to buy an adapter of some sort but it will work otherwise.
Old Oct 7, 2002 | 11:28 PM
Scotty's Avatar
Top's Younger Twin
[quote author=CMN_NOT_STROKN link=board=7;threadid=5647;start=0#49662 date=1034047162]<br>So I should be able to purchase a used one that is coming off of a 02 and put it on my 99, right? Just want to make sure since I won't be able to return it and I wanna be able to USE it! ;D<br>[/quote]<br><br>98.5 to 2000 are the same plugs<br>2001 are unique for that year only<br>2002 are different again.<br>I think that the internal programs for the older units are different too...An adapter will be needed but I do not know if theres a problem with using a 99 with an adapter to a 2002.<br>Maybe call to boys at Edge and they should be able to help.
Old Oct 8, 2002 | 07:23 AM
KatDiesel's Avatar
As stated 98.5 to 2000. On the 2000's the connection is different, but solved with an adapter.
In 2001 they also changed the voltages on the MAP sensor so a previous year box will definatly not work properly even if you &quot;rigged&quot; the connections.
2002 I know they changed the connection again but I am unaware of any programming changes that might have occured.
Old Oct 8, 2002 | 09:34 AM
Scotty's Avatar
Top's Younger Twin
[quote author=KatDiesel link=board=7;threadid=5647;start=0#49737 date=1034079834]<br>As stated 98.5 to 2000. On the 2000's the connection is different, but solved with an adapter.<br>In 2001 they also changed the voltages on the MAP sensor so a previous year box will definatly not work properly even if you &quot;rigged&quot; the connections.<br>2002 I know they changed the connection again but I am unaware of any programming changes that might have occured.<br>[/quote]<br><br>Thanks for clarifying what my old brain was trying to type Kat.<br><br> ;D<br><br>Scotty
hellotbone's Avatar
Give edge a call.
Old Oct 8, 2002 | 07:01 PM
I contacted Edge and they gave me the answer. A box from a 01 or an 02 will not work on a 98.5-00 since the voltage on the map sensor is different. Just like KatDiesel said. The 01 will work with an 02 but for the 02 you need an adapter since the plug itself is different.
Old Oct 8, 2002 | 11:11 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
I'm going to add to the MAP sensor voltage difference angle here:<br><br>With the .7 volt reading at idle of the 98.5 - 2000, you'd think that the 01/02 Comp would come in harder if hooked to one of these trucks, but it doesn't. Changes in the 01/02 ECM program required that Edge be less aggressive on 01/02 program than they were on the 98.5 - 2000. So putting an 01/02 Comp on a 98.5 - 2000 will actually result in a box that comes in slower than 98.5 box will. It will work, just not as well. It'll be like turning down the sub-fueling level.<br><br>Rod
Old Nov 21, 2024 | 07:12 PM
Jamesharrison@1's Avatar
out of DATE CUMMINS PROGRAMMER
Sounds Like To Me THAT The E.P.A. HAS PUT ( TUNNER'S ) OUT OF BUSINESSES """"
Old Nov 22, 2024 | 02:55 PM
SIXSLUG's Avatar
Well in 2002 when this post originated, it was a non issue
lvmknsmoke..
Jan 17, 2025 09:14 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
BigBlue
Mar 22, 2005 06:16 AM
