Cooper Discover STT?
I have a line on a set of used Cooper Discover STT tires (35x12.50x17) mounted on stock 17" rims with only about 6,000 miles on them. I have a 2001 Ram with 2" blocks in front. Will there be any clearance issues? Does anyone have any pictures of a similar truck with these tires or tires of a similar size?
Thanks
Thanks
I had a set of 35's on stock wheels with just 2" coil spacers in the front. The only time they ever rubbed was at full lock, and the tires would rub the lower control arms. Because of the backspacing of the factory wheels. Run em. I've heard alot of good things about the STT's.
Later,
Tommy
Later,
Tommy
Should I be concerned at all that I have 3.73 gears with the larger tires? Right now I am running 285/65/16 BFG's and was thinking of going a little larger since I have the leveling blocks in.
Any idea what a fair price for 4 of these tires used (6,000 miles) mounted and balanced would be?
Where did you find 3.73's at? I looked all over the place before I swapped in my 4.10's. I was told no one makes 3.73's for dana 70's or 80's. My truck was perfectly fine with the factory 3.54's and 35's.
Maybe they are 3.54 gears then? It has been a few years since I bought the truck used and I know they aren't 4.10's. I thought for some reason they were 3.73's? Were 3.73 gears an option on an '01 CTD?
Anyway....pull a 20' open trailer with a 3600lb car a few times a year and was a little concerned that the 35's with the stock gears (3.54's or 3.73's ???) would be a problem?
I have 315-75-16 (35") Cooper Discoverer STTs with a 2" leveling kit. I cut the inner fenders out quite a bit and they only rub when you're on a full turn and go over something like a curb
I ran 315 STTs on my 02 with no lift or leveling kit. Did not rub anywhere but on the control arms at full lock... chews up the largest lugs pretty well, so when it came time to rotate I had to do an un-orthidox tire rotation to keep the ugly chewed up lugs out of sight.
Freaking awesome tire though for any condition any terrain.
tcr
16
Jul 21, 2007 01:08 PM
1882
0
Aug 14, 2006 09:02 PM
Nick660
Apr 27, 2006 08:06 AM
Tomtt
Aug 25, 2005 08:27 PM
