Clutch advise
#61
DTR Advertiser
Re:Clutch advise
He might have a few HP, but he should go dyno that bad boy and see what it has to show the world and me how retarded I am. That would clear things up nicely. Hey how about trailering that White Beast to May Madness to stomp the guts outta everyone there? You might be able to come along too if the trailer is large enough to fit your truck on. <br><br>Don~<br>
#63
Re:Clutch advise
I would love to go-but last I heard- no truck pulls. No Dyno Jet would hold that thing anyway, as even I smoke the tires on them.<br>We need one that we can bolt the axles to.<br><br>Don, Rob, Peter.<br><br>Have any of you three actually measured a Mitchell clutch and flywheel?<br>No?<br><br>Then for all the three of you know, it is not machined at all.<br>No, Rob, don't take it out, I will tell you.
#64
Re:Clutch advise
[quote author=Sled Puller link=board=7;threadid=7805;start=60#77256 date=1039307339]<br>Don, Rob, Peter.<br><br>Have any of you three actually measured a Mitchell clutch and flywheel?<br>No?<br><br>Then for all the three of you know, it is not machined at all.<br>No, Rob, don't take it out, I will tell you. <br>[/quote]<br><br>Dangit,<br><br>I should have read this first, now I gotta put all the bolts back in. ;D<br><br>No Gene, I havent measured it yet, but when I do, I will keep it secret, the other guys will have to buy one to see for themselves.<br><br>Don, Dave showed me the dyno sheet from his truck the other day (he just dynoed) I will say that it was over 1000hp, however, my dog ate it, so you will just have to take my word for it. ;D<br><br>Also Don 'ol boy, a number of turbos also have exploded in the past, does that not concern you? Why must you try and pummel the baddest pulling clutch the world has ever seen, for one mishap, from one hellava truck? You know as a well as I, when you push things to the limit, something will eventually fail, somethimes a u-joint, or in your case, an injector tip falls off. <br><br>Later, Rob
dominojd
01-27-2013 10:07 AM
95ramtough
24
04-08-2003 08:58 PM
