catcher & boost fooler
Old Aug 15, 2005 | 09:57 AM
darrenG's Avatar
Does the catcher also act as a boost fooler? I know it's the computer replaced, and I'm sure it ignores boost for fueling, but I wanna be sure...
I'm tired of hitting 25psi+ w/ only a 4" exhaust and feeling the truck defuel.
Old Aug 15, 2005 | 10:00 AM
2500CTD's Avatar
Yip, it has a higher boost setting, dont know if there is limit or not. Also the defuel is either gone, or happens at a higher rpm
Old Aug 15, 2005 | 01:50 PM
Mike D's Avatar
Sure does. I've been hitting about 32 psi.
Old Aug 17, 2005 | 12:06 PM
latitud_rt's Avatar
You can't get boost above the factory wastegate of around 21 lbs unless you install the adjustable boost elbow. The catcher does ignore overboost, but the ECM can not control the wastegate. Boost elbow is around $15 delivered.
Old Aug 18, 2005 | 02:46 AM
2500CTD's Avatar
However with my truck I need the turnbuckle. Mike D how are you getting that high of boost. I'm really getting close to ordering my MAD.
Old Aug 18, 2005 | 09:29 AM
Mike D's Avatar
I'm using the boost elbow from when I had the EZ.
Killdmycobra
Nov 12, 2010 05:15 PM
Texasimport
Oct 9, 2008 02:39 PM
jmccart
Oct 2, 2007 12:17 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
Charlie8301
28
Nov 14, 2005 11:26 PM
