Trans shift pattern question?
Old Aug 17, 2005 | 09:21 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
Question Trans shift pattern question?
I have a 47RH trans Suncoast triple lock converter, clutchs with trantec/transgo valve body upgrade, i also have a converter lockup on switch installed. iI pulled last night at one of the local fairs in the area, in low range with the converter locked the trans would not shift up to 3rd gear what can i do to get it to shift into third?
Thanks
Chris
Old Aug 17, 2005 | 10:17 PM
cumminsdriver635's Avatar
Mine will?? It wont shift into 4th, but it will shift into 3rd locked. Hmm? Dont guess i can help you there?
Eric
Old Aug 17, 2005 | 11:47 PM
Crimedog's Avatar
It's dangerous shifting while locked during a pull, especially with a tight torque converter. I bet the input wouldn't have liked that shift it wouldhave gone to 3rd. Anyway, it should shift up to third, the only thing I can think of is maybe with it locked in 2nd you aren't revving enough to cause it to shift. Did you happen to glance at the tach?
Old Aug 18, 2005 | 11:09 AM
chop342's Avatar
ya the tach was about 2500 RPM, i forgot to mention im not worried about the input shaft all are case hardend. i guess it could just not have had the tires goin fast enough to shift into third.
Thanks
Chris
Old Aug 18, 2005 | 11:47 AM
Get you a 3k GSK and it wont need to shift. Or a 4k if you really want to wind her up.
Eric
rich
22
Mar 30, 2005 04:37 PM
schu
15
May 26, 2004 01:56 PM
BuckBoardDriver
Jul 8, 2003 04:39 PM
TDC
Mar 3, 2003 07:40 PM
gofastman
Feb 6, 2003 07:28 PM
