View Poll Results: Does an 03 need a boost fooler with a Power Puck?
Yes, you need a BF
13
39.39%
No, you do not need a BF
6.06%
I really have not idea but wanted to vote anyway!!!
18
54.55%
Voters: 33. You may not vote on this poll
Boost Fooler or No Boost Fooler?
Old Jun 13, 2007 | 10:28 AM
Rollin' Smoke's Avatar
this is for a 03 CTD HO 3500 with the power puck and a boost elbow only.....i have gotten so many different answers to this question when i asked that I am posting a poll. Do you really need one or not!
hopefully this will clear the air!
Old Jun 13, 2007 | 10:29 AM
JD Dearden's Avatar
There like 20$ and 10 min of wiring just get it.
Old Jun 13, 2007 | 04:05 PM
tbarbee1's Avatar
He's right go for it. Look in the classifieds.
Old Jun 14, 2007 | 06:27 AM
2broke2smoke's Avatar
i wouldn't spin that little hy any more than stock ...
if the power puck came with a boost elbow are you sure it's not doing a little boost fooling already ...
Old Jun 14, 2007 | 08:43 AM
tristan21's Avatar
Jeremy at quad told me that most boxes do boost fooling these days. Heck he said that the MP-8 does BF. Seemed surprising to me. I have a gauge and he said if its gettin 39-43 psi of boost on your gauge your getting boost fooling. Dont know if that helps. it did me.
Old Jun 14, 2007 | 09:05 AM
qzilla's Avatar
OK, 03-04 trucks are 100% completely different than 04.5-07 trucks. I know they look the same and sound the same but, they are NOT the same.
The 03-04 trucks have a different turbo and they cannot handle what the 600 trucks can.
You need a boost fooler if you are going to run an elbow. I would bet $1 you already have overboost codes in your truck right now. When the truck cuts fueling back because of it, its not like 1/2 power is gone, it just scales fueling back a lot at those levels. On a dyno you can see it a lot and on the street a little.
Old Jun 14, 2007 | 09:33 AM
tristan21's Avatar
I didnt even notice that quad thanks for correctin me. I guess I should better check out the sig before I go runnin my mouth.
Old Jun 14, 2007 | 02:54 PM
well there is no doubt that I have the code, but have not noticed any difference in power. runs very well IMO. If it cuts to 1/2 power you would really be able to tell , but i havent seen that!
Old Jun 14, 2007 | 03:02 PM
qzilla's Avatar
Its not going to make it where you cannot drive it, but, it will cut fuel back especially up top where the boost is higher.
Old Jun 14, 2007 | 03:08 PM
JD Dearden's Avatar
I was making right around 50psi before the fooler I was pulling my boat and went to pass a mobil home being transported when I pulled out and got on the side of it one of the lanes ended and I had someone coming quick so I mashed the pedal in 5th and got to 2900 rpm's when the engine started to seize up then shifted to 6th and pulled through. I had the boost fooler put on it no longer will do this and I make a little more boost
Old Jun 14, 2007 | 03:21 PM
your say that I am actually losing some power on the topend because of the code for overboost. My truck will actually perform better than it already does when I get the fooler installed?
I cant imagine it doing better than it already does........ WHOOOOO!!!!!!!
Old Jun 14, 2007 | 03:24 PM
35" 05''s Avatar
where have you seen them for 20$?
Old Jun 14, 2007 | 03:29 PM
JD Dearden's Avatar
My shop Wide Open but that is what they charged me not sure what they sell them for do you know what I mean?
Old Jun 14, 2007 | 03:31 PM
well that makes a difference doesnt it!
Old Jun 14, 2007 | 03:33 PM
JD Dearden's Avatar
If I remeber right they where 18$
