Bull Bar
Old Apr 7, 2005 | 06:10 AM
crobtex's Avatar
Bull Bar
Does a Bull Bar with lights improve high beam road visiability?
Old Apr 7, 2005 | 08:40 AM
HOHN's Avatar
I'd think adding lights would always help.
jlh
Old Apr 7, 2005 | 08:48 AM
RowJ's Avatar
Re: Bull Bar
Have you tried this modification. Works very well!
https://www.dieseltruckresource.com/...threadid=25841
RJ
Old Apr 7, 2005 | 10:54 AM
crobtex's Avatar
Hmmmmmmmm......that sounds like a cheap fix!
Old Apr 7, 2005 | 11:35 AM
crobtex's Avatar
I'm a little confused.
I have found two light green wires....one is kinda lime green. One does nothing when the low beam is on, and the other puts out about .44 volts. Which is correct?
The violet/white has a constant 12 v. Is this the correct one?
Old Apr 7, 2005 | 11:52 AM
crobtex's Avatar
Now I'm really confused.
The lime green has 12v with low beam switch "off" and none with it on.
The violet/white has 12v with the high beam on.
Are these the right two?
Old Apr 7, 2005 | 12:17 PM
crobtex's Avatar
Well, I connected the lime green to the violet/white. At least no blow fuses, etc. It appears to be right, but can't really tell how well until dark.
Now, if can just figure out how to get the stripped out headlight adjust screws fixed. Two of the torque screws are stripped and I can't figure out how to get the top side nut, or whatever it is off.
Old Apr 7, 2005 | 12:50 PM
pittom's Avatar
drill bit
Old Apr 7, 2005 | 12:56 PM
pittom's Avatar
I used a relay and fuse to turn on low when i put on high.I did it this way so there is no extra amps on the wires under dash.
At the high light,(at the bulb)when trigered that would trigger relay then the power would come right from batt.(trough a fuse first).
Old Apr 7, 2005 | 01:10 PM
crobtex's Avatar
I guess I'm not smart enough to understand the extra amps. I left them on for awhile and did not feel the wires getting hot, or even warm.
Old Apr 7, 2005 | 01:17 PM
crobtex's Avatar
drill bit
I thought about that. The problem is that you still have to get the screws out. Also, you can't buy just the screws....you have to get the whole assembly. If I can get the whole thing out, I will saw a cross slot in the screw head where I can use a screw driver to do the adjust.
I've tried to find a "broach" bit (drills square holes) but haven't had any luck for something that small.
Thanks for the reply,
Old Apr 7, 2005 | 01:22 PM
RowJ's Avatar
You want the one that the current goes on & off when you switch LOW beams on & off. If you did it wrong...i believe it's the flashers that would come on with the high beans. Sounds like you got it right.
RJ
Old Apr 7, 2005 | 10:14 PM
taken5875's Avatar
craftsman cells a screw extractor kit for $15 or $20 so as long as don't need to turn them in this would help
Old Apr 18, 2005 | 07:41 AM
crobtex's Avatar
It Works!
Connecting the two wires keeps the lows on with the highs, and it sure makes a lot of difference. All I gotta do now is get them pointed in the right direction.
Thanks for the help...........
mike4089
Dec 6, 2012 08:00 PM
Mexstan
Dec 27, 2009 01:51 PM
brianblack138
Feb 15, 2009 01:31 AM
Jme
20
Dec 27, 2006 08:44 PM
unbob
Sep 4, 2005 10:38 PM
