Boost gauge
Old May 10, 2007 | 03:11 PM
superuke's Avatar
Boost gauge
Recieved the boost gauge yesterday.. It has looks like a clear 1/8" plastic tube with a " T ", obviously to splice into an existing line.. Where can I find the line to put the T in?? .. I also got the 3 gauge pillar mount with the following gauges.. EGT, Boost, & Trans... Is there a preference in mounting the gauges in the pillar? e.g. boost on top, or Trans, etc. etc?? The EGT gauge I got looks like it goes to 2400, so it makes the numbers rather small..
Thanks in advance
Old May 10, 2007 | 05:01 PM
Common's Avatar
Thanks in advance
You don't "T" into anything...
Under your intake horn, just towards the front of the motor, there is a bolt on the intake manifold that you remove and plug in there...
So basically:
1. Locate and remove the 1/8" NPT pipe plug on the driver's side of the intake manifold towards the front of the motor.
2. Install a fitting (not included with the gauge) and connect the hose making sure that the hose fits snug but does not pinch.
Old May 10, 2007 | 05:59 PM
superuke's Avatar
So basically:
Thank you very much.. I wonder why they never put that in the instructions?? would make it so much easier.. I would have to purchase a 1/8" fitting for the hose, is that correct?? Also are there any preferences where each gauge goes?? thanks
Old May 10, 2007 | 06:00 PM
Common's Avatar
Its entirely up to you where to put the gauges.
Old May 13, 2007 | 10:27 AM
superuke's Avatar
So basically:
Ok got the fitting installed after running all over the city trying to find one.. Also had to get a longer tube.. My gauge reads 0 at idle, & about 5 when I rev it up to 2000.. Is this about normal??
I also notice you have a #10 plate not installed.. are you still planning to install it??
Old May 13, 2007 | 10:33 AM
scottsjeeprolet's Avatar
You won't see any boost just from revving the engine. You need to take it for a ride. Then you will see boost as the engine is under a load.
Old May 13, 2007 | 10:44 AM
superuke's Avatar
Ok, thanks.. I'll give her a go...
Old May 13, 2007 | 11:13 AM
odin1954's Avatar
Yea I got the same kit three gauges , I put the EGT on top than turbo boost and trans temp they work you wont see the boost till get goin down the road
Old May 13, 2007 | 12:01 PM
b.lee's Avatar
I got my #10 plate + 3k gsk installed and when running it hard, it will slip the t/c. The #6 plate will slip the t/c real bad. Also might want to consider an 4" or 5" exhaust, and boost elbow to reduce your egt's once the #6 is installed.
Old May 13, 2007 | 12:24 PM
superuke's Avatar
So would a #8 be better, & give less slippage??
Old May 13, 2007 | 12:26 PM
I would say if your TC is or has slipped then it is on it's way to the grave. Start looking and saving for a TC & VB upgrade.
Old May 13, 2007 | 12:41 PM
b.lee's Avatar
ya, but mine slips with a #10.
it all depends on the truck.
Im getting a TC soon, maybe a bullet proof trans.
Old May 13, 2007 | 12:43 PM
superuke's Avatar
Do you have any links to a TC & VB ?? Can I put in a VB, or does a trans shop have to do it?? Would I need a shift kit in conjunction with a VB, or is the shift kit a part of the VB ?
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
