boost gauge install and no boost
Old Feb 27, 2008 | 08:42 PM
Tank_66's Avatar
Well I finally got around to installing my boost gauge and all went very well... I driller and tapped the intake horn and ran some tubing threw a gromet in firewall.. and tightened everything back up.. and starrt truck adn no boost how did I bugger this up HELP PLEASE. this is annoying
Old Feb 27, 2008 | 08:44 PM
53 willys's Avatar
so you took it on a test drive and the gauge does not move at all??
is the line kinked??
Old Feb 27, 2008 | 08:45 PM
opietrice's Avatar
you have to put the engine under a load to show boost.. take for a test drive and it will show boost.
Old Feb 27, 2008 | 09:05 PM
Billm2004's Avatar
i once got a bad boost gauge from autometer. it wouldnt show boost after i installed it either, i had to send it back for another one
Old Feb 27, 2008 | 11:47 PM
06megacabman's Avatar
You won't see boost at idle or even revving it for that matter. Drive it and press the go pedal hard. You will see boost.
Unless it's a bad gauge of course.
Old Feb 28, 2008 | 06:29 PM
Tank_66's Avatar
checked the line, pulled it off the gauge and sucked on back of gauge and right up to 30 psi sucked on the line to intake and free as a bird. I'm confiused
Old Feb 28, 2008 | 06:39 PM
soulezoo's Avatar
DTR 1st Sergeant
What brand? Is it electric or mechanical?
Old Feb 28, 2008 | 08:34 PM
louddodge's Avatar
Sounds like your line is kinked or split
ado2b1
Jul 6, 2007 10:27 PM
MoparMarv
May 4, 2006 04:41 PM
Mr. Jimmy
Jan 20, 2006 03:51 PM
Flatty
Apr 25, 2005 02:17 PM
