Boost Fooler or Elbow
Old Mar 28, 2005 | 05:43 PM
CODODGE2500MAN's Avatar
What's the difference between the two?
Which one should I get?
Where do I get one?
Old Mar 28, 2005 | 05:49 PM
phox_mulder's Avatar
Someone asked the same question a week or so ago.
https://www.dieseltruckresource.com/...threadid=64144
phox
Old Mar 28, 2005 | 05:52 PM
smokindog's Avatar
The elbow is at the turbo and will increase the amount of boost before it wastegates depending on how far it is cranked in. The fooler is usually part of a fueling box which sends a phony signal to the ECM to allow you to overfuel.
The elbow can be purchased individually for about $12, but the fooler is usually part of the fueling box package which can range anywhere from $400-$900.
If you just get the elbow it will allow the turbo to make more boost, but the ECM will back out the fuel and you will lean out the truck. Get both, you won't be disappointed!
Old Mar 28, 2005 | 05:57 PM
smokindog's Avatar
Ok,
Phox beat me to the punch, but the link he provided is 100%!!!
Old Mar 28, 2005 | 06:03 PM
HOdiesel80's Avatar
CODODGE2500MAN, I asked the same thing last week like Phox said. It is currently on page 5 of this forum. Or you could do a search for boost fooler/elbow or both. It should point you in the right direction. I just ordered mine from the site Phox gave you.
Old Mar 28, 2005 | 09:44 PM
THANKS GUYS.
Old Mar 28, 2005 | 09:47 PM
Is there a boost fooler in the edge comp? I'm thinking of getting that, so maybe i should just hang on and buy that?
Old Mar 28, 2005 | 09:57 PM
Yes, both the Edge EZ and Edge Comp have a built in boost fooler.
phox
Old Mar 29, 2005 | 12:25 PM
am I mistaken or does one of them/ or both, come with the elbow?
Old Mar 29, 2005 | 02:54 PM
I SPEED's Avatar
The Comp comes with the elbow, but you can't use it with the Auto trans. Only the M/T trucks can use the elbow.
I used a homemade turnbuckle to increase boost. Search under turnbuckle for info.
Old Mar 29, 2005 | 08:26 PM
macjazzy's Avatar
I admit to being confused as to what a boost fooler and elbow was but this thread has been great for educating me. It sounds like I need or at least want one.
I have a 2002 h.o. 6 spd that I have added 4 in" mbrp exhaust, and a Van Akaan box. I don't think it has a boost fooler. It is an older box I bought it used from a friend who had it on a 1999. It has one plug that plugs inline into the vp44.
Anyway I have looked on all the websites listed in the links section here and could not find any boost foolers or elbows.
So where do I go or what do I need?
Old Mar 29, 2005 | 09:03 PM
After a very short search, I found one place that sells the standalone boost fooler
http://www.usdieselparts.com/1055921.cfm
If you Van Akaan box doesn't plug inline between the MAP Sensor and it's plut, then it doesn't have a boost fooler.
As to a boost elbow, you can get one directly from Edge (www.edgeproducts.com), just give them a call, or do the turnbuckle method mentioned above.
phox
Old Mar 30, 2005 | 08:30 AM
macjazzy's Avatar
Thanks, I checked it out and it says that the boost fooler has an orifice to put n line with the waste gate, does this mean I don't need the elbow with this boost fooler?
Also one other thing I am not too sure about reading all the other posts.Will I see a performance increase with these two mods alone with the upgrades I have so far, or is it mostly to keep egt's down? Because I don't have a problem with my egt's right now.
So is this more for people with lots of hp and bombs or will those of us with light mods/bombs feel/notice a difference in seat of the pants power?
Thanks for your help
Old Mar 30, 2005 | 11:32 AM
Wilson's Avatar
Came across this while checking out some classified ads. Maybe it will be useful to somebody.
http://www.turbodieselregister.com/c...uery=retrieval
Hdog
Oct 27, 2014 10:52 AM
Killdmycobra
Nov 12, 2010 05:15 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
Palmetto_kid
Jan 16, 2004 02:21 PM
