banjos and warranty
banjos and warranty
is my warranty affected if i use genos banjo kit,or should i drill out the factory ones. im able to pull the pessure down to about 7psi with my comp box Without the the pump wire tapped
thanks in advance ,
Adam
thanks in advance ,
Adam
www.wildcatdiesel.com is a site sponsor and also has the Hi-Flow Banjo Bolts.
And they're already on your side of the border.
One thing to keep in mind if you switch out the banjos, you lose the two schrader valves used to check fuel pressure. If you take the truck in to the dealer to have the lift pump done under warranty, the dealer might have something to say about that.
Unless you just do like most and do the lift pump yourself.
