what size threads on banjos
^^^^^What he said,^^^^^ and the lift-pump outlet is 14MMx1.5.
I ?think? the lift-pump inlet is 1/4-NPT, but it could also be 14MMx1.5.
The confusion is 1/4-NPT will easily thread into a 14MMx1.5 hole, and I have even managed to make them work drip-free; but, the 14MM threads are straight threads, whereas the 1/4-NPT threads taper.
this is my first winter with the truck and seems a little cranky If I turn the key on 3 or 4 times and let the grid heater go off every time it will start but if I just go once it's a no go.
Also is there anyway a plumbing supply or something local might carry those metric threads
I buy mine from here :
http://www.discounthydraulichose.com...068-parent.htm
What you will have to do is use the METRIC/JIC adapter, then a JIC-SWIVEL, then plug the fuel-line to that.
I have never been able to find plain old Metric/HOSE-BARB fittings, without first having to go JIC.
JIC is better, anyway.
