Back up lights
Back up lights
Help, i cant find the threads on Back up lights and extra switches. Can anyone recal where and what there under.
THanks
ROb
THanks
ROb
Found a few with a quick search for "reverse lights":
https://www.dieseltruckresource.com/...reverse+lights
https://www.dieseltruckresource.com/...d.php?t=185243
Hope this helps. If not, do a search for "reverse lights." That might give you some more options.
here is what i did on my truck this summer:
https://www.dieseltruckresource.com/...d.php?t=217334
i used a diagram i found on here to help with the wiring - can't seem to track it down
ok, found some diagrams from another i thread i started in order to track them down in the first place:
link to the thread:
https://www.dieseltruckresource.com/...lights+diagram
hope this helps you out.
later,
jason
ok, i found what i needed here:
https://www.dieseltruckresource.com/...d.php?t=147273
(i guess my original description was a little off!)
and another one here:
http://www.snowplowing-contractors.c...se_lights.html
later,
jason
Cheap tractor lights from Napa, wired into the stock reverse light wiring. Very helpful especially with tinted windows. Why did Dodge put such crappy lights on these trucks, the headlamps are terrible and the backup lamps aren't much better.
Here's mine. Cheap NAPA tractor lights, swapped to aircraft bulbs, relay triggered of the reverse lights, wired directly to the battery and fused of course.
Dave
Dave
03CTDCO
03-06-2010 10:48 PM
getrdun
11-26-2008 11:46 AM
proudpapa97
05-04-2008 06:50 PM
JoshPeters
04-03-2005 08:13 AM
CHarlan
08-06-2003 08:40 PM
