air dog off of 03 use it on 12valve?
Old Jun 12, 2009 | 09:21 AM
kyle_truck_pull's Avatar
Question air dog off of 03 use it on 12valve?
is there any way that you can use the air dog off of my common rail and put it on my 12 valve? will it work? whats different? I dont need the airdog on my 03 anymore and i want to put something on my 12 valve but I dont know what pump to use on these 12valves, and would like to save the cash
Old Jun 15, 2009 | 10:55 AM
dzlfarmboy's Avatar
Not 100% sure but you might be able to just get a different relief spring that would bump the pressure up to 40psi or so. The CR psi would be too low for your 12v.
Old Jun 16, 2009 | 01:43 PM
hamilton71801's Avatar
Originally Posted by AirDog
There are a few things different. The wiring harness different. The 12mm fitting that fits into the injection pump of the cp3 is now a 14mm into the p pump. Our kits for the 12 Valve also come with the fittings needed to connect the injector return and the pump return together. You will also need to purchase a 30 psi spring. Its a whopping $3.50 I think. That should be enough to fix you up. Let me know if you have any questions. Thanks
What a deal. That sounds like some good cust service right there. Anyone who believes in not screwin someone is alright in my book. Airdog, when my Carter takes a dump, I'm giving you a call.
Old Jun 16, 2009 | 10:34 PM
let me know what the total cost would be to make it work, thanks!
Old Jun 17, 2009 | 06:47 AM
JohnBer's Avatar
I agree! i will changing over soon also, think it wont be long and i will have outgrown the stock lift pump. Now to talk the wife into another toy for my toy.
duster75
Sep 9, 2009 11:02 PM
trailinone
16
Jun 19, 2009 04:28 PM
herb
Jul 18, 2008 08:25 AM
97Smoker
Aug 31, 2007 05:00 PM
bocuso
27
Jan 18, 2007 12:54 PM
