97 12valve jerks taking off
Old Aug 22, 2007 | 09:00 PM
97Smoker's Avatar
Ive been noticing alot lately that my truck jerks when taking off from a stop. I had my g/n on it this weekend and couldnt hardly back up with it because of it jerking/bouncing so bad. I think i need new U-joints but i wanted to post on here and see what ya'll thought about it.
Thanks
97Smoker
Old Aug 22, 2007 | 10:04 PM
zspear1's Avatar
How many miles on the clutch? I am assmuing it is a 5 speed since your sig is bare. A pressure plate and a flywheel can get burn spots or what some mechanics call a hot spot. Comes from the clutch disc slipping in between clutch and pressure plate during partial engagment like moving through slow traffic getting started with a heavy load and backing up to a trailer, Pretty common on trucks that pull and have a great deal of low end torque seems to come at some time during their lives. Some live along time with it. SOme good pulling usually helps mine stop doing it for awhile. City driving makes it come back faster than anything else.
Old Aug 23, 2007 | 06:20 PM
97Smoker's Avatar
I just put a new 13" flywheel and clutch 450hp 950tq about 2,000 miles ago. And yes it is a 5spd sorry bout that. All i have done to the truck right now is wastegate blocked, open 8" K&N filter, and the torque plate is removed, its only around 350 hp, and maybe 650 or so torque.
Old Aug 23, 2007 | 07:27 PM
TxDiesel007's Avatar
Thanks
97Smoker
U might wanna check
the u joints, or the throttle return springs on your injection pump. thats a major cause for trailer bucking if they arent all there, if its not ur u joints.. Truck does that only loaded? or empty as well... If ur clutch is ceramic, let it better break in and things will get better. Ive got 25K on my valair inc, and its been a heck of a clutch.. pulls trailers like a dream...
Rick
Old Aug 23, 2007 | 09:58 PM
MikeR's Avatar
The new flywheel may not have been perfectly flat after shipping. I have found flywheels with a couple thou runout therefore causing hop or chatter (jerkyness).
Anytime we do clutches at the shop now I always send the new flywheel out that way I know it's a perfectly flat no runout. Always had better results since I've been douing that.
Old Aug 23, 2007 | 10:24 PM
dieselman2300's Avatar
What kind of clutch is it? There are some out there that are very jerky (technical term) while backing up and starting out.
Old Aug 25, 2007 | 02:57 PM
Baja's Avatar
My guess is the clutch, if it is like mine, a Con OFE, to make it aggresive and hold the hp, the material in the clutch is pretty grabby. I called Southbend about it when my clutch was new and they told me to give it more throttle as you let it out. When new, reverse was really grabby, far worse than first. It is getting better, but it is taking a long time. Overall, I like it and am glad I put it in. Did your new clutch come with a flywheel?
Old Aug 31, 2007 | 05:00 PM
97Smoker's Avatar
Yes the clutch did come with a new 13" flywheel.
dtenorio
May 2, 2010 04:26 PM
kyle_truck_pull
Jun 18, 2009 01:53 PM
davinski
Apr 20, 2009 10:21 AM
kamahao loo
Nov 4, 2007 06:43 PM
Dieseldude4x4
Dec 23, 2002 09:28 AM
