air dog or fass
air dog or fass
Ok im about to install a new injection pump on my 99 dodge my truck is set with 50 hp injectors and I run a smarty but I have a tst hot box that im trying to still run as well. Im trying to figure out what I should do about my lift pump and which set up I should go with to have a steady fuel pressure.if anyone has some suggestions I could really use it
.lol
.lol
Save your $$$ and buy a holley blue and install a spin-on pre filter. Mount it as close to the tank as you reasonably can and wire w/#12. Cost is roughly $175 at most. This setup has worked well for about 4 years 16psi at idle and 13wot. Tons of info on here regarding the LP options. JMO
I have the Airdog 150 on my truck, no problems in the last year and a half. I have heard some good things about the FASS as well. You probably cannot make a bad decision between the two.
Had a fass for years but just switched to an Air Dog II 165 gph pump..
It's simply Amazing how much quieter it is than both of my fass pump were..
Air Dog II gets my vote...
trailinone
16
Jun 19, 2009 04:28 PM
rmrc
Feb 13, 2005 05:25 PM
hialtitude
Oct 27, 2004 08:46 PM
AK RAM
19
Jul 28, 2004 04:54 PM
