Aftermarket Tachometer
Old Apr 1, 2007 | 11:47 PM
ciscohusker's Avatar
Has anyone added an aftermarket tach and if so what did you add and where did you get it. I can't run it off of the alternator (don't have one) and am using a fluid dampr.
Thanks
Old Apr 1, 2007 | 11:49 PM
getblown5.9's Avatar
you can still use the fluidamper, just have to get a setup that uses a piece of reflective tape on the damper and an optical pickup.
i assume this is for something of a race only nature since you said it doesnt have an alternator.
Old Apr 2, 2007 | 08:28 AM
This is going on a dedicated truck puller and the motor is stripped of all belt driven accs. do you have any experience with a specific tach?
Old Apr 2, 2007 | 08:43 AM
no sorry i don't but i know for a fact i've seen pics of the big time pullers (haisley,scheids etc) and their motors dont have belt accessories, and i remember seeing a tech pick up on the damper.
maybe contact those folks and find out what they use for a tach?
Old Apr 2, 2007 | 08:48 AM
here i found the pic and its with a fluidamper.
website is www.smoknya.com
Old Apr 2, 2007 | 10:30 AM
infidel's Avatar
These don't look fancy but are highly accurate and not very expensive.
Run off pulses from an injector line.
http://www.tinytach.com/tinytach/diesel.php
Old Apr 2, 2007 | 10:34 AM
haloman's Avatar
I have one of those in my 91' worked great but my only complaint was no backlight. I am sure someone could rig something up to have one.
Old Apr 3, 2007 | 11:11 PM
joefarmer's Avatar
I run the tach pickup from Isspro with an ATI superdamper.
http://www.isspro.com/categories.php?cat=139
brandon.
Old Apr 9, 2007 | 08:58 AM
brandon.
What tach are you using with that pickup? I was hoping to use the stock magnetic pickup with an aftermarket tach from Autometer or Isspro, actually brand doesn't matter function does.
Old Apr 10, 2007 | 03:03 PM
joefarmer's Avatar
The factory '98 dash tach.
brandon.
FORDNOMORE
Sep 10, 2003 01:06 AM
Paul Winey
Feb 21, 2003 08:39 AM
buckshot
Jan 21, 2003 12:24 AM
frankie9510
Jan 10, 2003 03:19 PM
Rammer64
Oct 7, 2002 07:17 AM
