Looking for ideas on sound attenuation
Old Apr 5, 2007 | 12:19 PM
captnfrenchy's Avatar
Do a lot of highway miles and looking for ways to decrease the noise in the cab, I heard of tearing out the flooring and putting sound insulation underneath. Anything else.
Old Apr 5, 2007 | 12:22 PM
99globalwarmer's Avatar
dyna mat the hol inside of the truck. and spray the bottom underside of cab with dyna spray.
http://dynamat.com/products_automoti...remeliner.html
Old Apr 5, 2007 | 12:57 PM
Valv's Avatar
Yeah, did you check the price ? $ 140.00 for a 2ft x 3ft !!!
You need at least 4 of them if not more, it's cheaper buying a new truck !!!!!!
Old Apr 5, 2007 | 01:51 PM
you can check on ebay the prices are alot cheaper like 100 for like a 200 foot roll of extreme
Old Apr 5, 2007 | 01:54 PM
Tiger Rag's Avatar
Here should be some good reading:
http://www.turbodieselregister.com/f...ht=quiet+truck
http://www.turbodieselregister.com/f...ght=noise+****
Try these links and see if they work for you.
I used Fat Mat instead of dynamat. There are a bunch of other mfgrs out there too. Fat Mat is also on eBay.....their shipping is slow though.
JC Whitney also has a heavy duty insulation that helps on the back wall of the cab. You have to use your own spray adhesive, but it cuts down on some additional noise.
Old Apr 5, 2007 | 04:24 PM
LanceD's Avatar
you don't need that stuff, go to a place that sells roofing supplies and get a few rolls of black ice. I think thats what its called. its the same as dynamat, just thinner. but you will be able to buy enough to coat your whole cab 3 times for cheaper than 1 coat of dynamat.
Old Apr 5, 2007 | 06:25 PM
ya that black ice stuff does work well i had some left over from a job and did the inside of my doors man it completely slipped my brain.
Old Apr 5, 2007 | 10:25 PM
1stGen545's Avatar
The realy bad spot is the back of the cab, there is nothing but bare metal back there and thats were I think 75% of the sound comes from.
Old Apr 6, 2007 | 06:57 AM
Valv's Avatar
The back window is where a lot comes through, I thought to put a soft rubber strip between cab and box to stop some of the exhaust noise coming in, it will work in summertime but in winter with snow it will pack there, freeze and squeak.
Old Apr 10, 2007 | 07:33 AM
Thanks for all the good ideas, I have a few places to start looking.
Old Apr 10, 2007 | 01:31 PM
74dart's Avatar
I was told at a audio installation store that when dynamat was too expensive he sprayed the entire cab of his F-250 with bed liner twice. Said it worked great at over half the cost.
Old Apr 10, 2007 | 05:33 PM
Tiger Rag's Avatar
The sound control companies make a liquid application as well. There are enough competitors out there now that has brought the price down on the stuff. Just look around and buy the bulk lot.
samiam4
Dec 19, 2012 12:08 PM
kawi600
Aug 14, 2009 08:33 AM
junkyarddog_88
Feb 6, 2009 02:19 PM
theIntlEggrole
Jul 16, 2007 05:53 PM
FloridaTruckLover
Nov 28, 2002 08:20 AM
