ticking, rhythmic thud in engine sound, ideas?
Old Aug 12, 2009 | 06:51 PM
kawi600's Avatar
I did a lot of hard driving over the weekend towing stuff and playing with ricers . I noticed now I have rhythmic ticking sound thats constant and a pause with almost a thud sound after each 6 strokes. Makes the truck sound odd. Does not sound healthy to me at all.
Oil looks clean (black as ink, as usual. No metal or fuel contamination that I can see. engine makes great power. Smokey as always.
I did the old shadetree 'stethoscope' trick and seems like the tapping is most noticeable at #4 valve cover. I might take a peek in there next time I can work on the truck
Anyone have ideas on what to look for? Obviously Ill try loosening injector lines one at a time to see if it follows.. but what about diagnosing stuff like bent pushrods? Im used to working on OHC motors .
I have hamilton valve springs, the spendy beehive type.. and am still running a 3k gov kit on the pump (safer, IMO) so I doubt I floated a valve.
Old Aug 12, 2009 | 08:30 PM
Riflemanusmc's Avatar
Registered user
Have you cut your filter apart and checked for any metal...
Old Aug 12, 2009 | 09:39 PM
kawi600's Avatar
Ill change the oil and do that soon
Old Aug 14, 2009 | 08:33 AM
kawi600's Avatar
Ya know I feel like a real idiot on this one. It turned out to be the valve adjustment.
I had a cam, lifters and tappets installed recently and I guess theyre just bedding in. So there was a lot of extra clearance in some of the valves. That made the motor run rough on a couple cylinders and gave me that thudding / ticking.
Im doing the oil change and analysis regardless. Just to make sure theres no babbitt metal in there, etc.
It will probably show a bunch of wear metals from the pushrods and tappets.
1985cucv
Apr 11, 2010 10:42 AM
Lightman
Jan 9, 2010 09:26 PM
chrisminx
Jan 22, 2009 09:22 AM
Dave88LX
25
Jun 15, 2007 08:12 AM
Dynocon
Feb 26, 2006 10:21 AM
