98.5 that is lazy???
Old Jan 15, 2006 | 04:40 PM
STACKED's Avatar
my 98.5 feels a a bit to lazy. it has a dr. pef stg4 with their 100 horse sticks and it doesn't seem like it runs good for what it has. im going to try stacking a blue box on it and see what happens unless i should try something else?
Old Jan 15, 2006 | 05:20 PM
AlpineRAM's Avatar
If it is losing power you should not add another box as a band aid- Get the truck checked for codes, measure fuel pressure, check air filter and all that small stuff instead. I'd also check all the connectors of the box.
I do recall some of the Dr. Performance products being discussed in some forums, some comments on the boxes not working correctly wthout setting codes IIRC.
If the truck is an auto you might just be slipping the tranny and not get the power to the axle.
AlpineRAM
Old Jan 15, 2006 | 09:46 PM
STACKED's Avatar
no its a stand. but and i'm sure the chip is hooked up right but it just seems a little slow. do you think i could need a bigger turbo.
Old Jan 15, 2006 | 09:56 PM
BigBlue's Avatar
Go and have the codes pulled at autozone. Do you have a fuel pressure gauge? What's your fuel pressure at? How many miles on the truck?
Old Jan 15, 2006 | 11:35 PM
STACKED's Avatar
there are about 170k on it and last time i had a chip stacked on it a boost code came up but thats been a while. i had an 02 also and it with i dr. perf. stg3 and it ran better than my 98 that has sticks and a chip
Old Jan 16, 2006 | 01:37 AM
BigBlue's Avatar
I'm willing to bet that the injection pump is on it's way out. There's no reason why your 98 shouldn't scream with those mods.
Old Jan 16, 2006 | 02:38 PM
STACKED's Avatar
if it is going out then it has been going out for 20k. i want more but im not shure what the next mod should be.
Old Jan 16, 2006 | 02:45 PM
BigBlue's Avatar
It's not uncommon for them to take a long time to die. My buddy rjohnson didn't even realize his was dead until he couldn't build boost off the line and only dynoed 450hp with mach 4's, TST/EZ, water/meth, and an HX55.
Old Jan 16, 2006 | 02:46 PM
gandrews's Avatar
In addition to fuel pressure I would look at the boost.
Do you have a boost gauge, what boost are you seeing from your turbo?
Do you have a boost leak? Do you have a lot of smoke?
Good luck
George
Old Jan 16, 2006 | 03:15 PM
STACKED's Avatar
no hardly any smoke i thought that was a little strange and i need some gauges just dont have any.
Old Jan 16, 2006 | 04:59 PM
BigBlue's Avatar
You oughta put out a pretty decent cloud with that stuff. I'm betting that your lift pump and possibly your injection pump is dead. Go and have the codes pulled at autozone and see what they pull up. Hope it's not a P0216 code.
Old Jan 16, 2006 | 08:49 PM
Big Deezul's Avatar
a phat turbo
Old Jan 16, 2006 | 09:03 PM
cummnz4x4pwr's Avatar
I'm a dealer with dr perf. and I have had to defect over ten boxes in the last 6 months
I now refuse to sell them any longer Im not dissing your truck or nothin its just i think with my experience that their CRAP
jmo
jake
Old Jan 17, 2006 | 04:58 PM
STACKED's Avatar
thanks for the info i will try the codes and see what happens
GFB
May 26, 2007 12:38 PM
steelblitzkrieg
Dec 21, 2006 07:38 PM
corn binder
Dec 2, 2006 10:24 PM
BigBlue
Jul 24, 2006 12:29 AM
00Dog
Apr 27, 2006 02:16 PM
