5th gauge
5th gauge
What should I get for my 5th gauge? I've got Fuel Pressure, Boost, EGT, and transmission temperature. I was thinking oil pressure next. Does ISSPRO make an oil pressure gauge? My goal with this truck is 600 rwhp daily driven so what do yall think would be the best gauge to get? Thanks for the help yall.
Comp(in EZ mode) and 275's are being thrown in this january and that'll be it until I get the money for a new tranny. I'm trying to get all of my supporting systems up and running so I have an idea what's good and bad before I get into the real heavy bombing (Drag comp, Mach 6, head, cam, twins, the usual
Second Exahust guage
It might possible to to gain somethng by a second exahaust gauge mointering down strean exhaust after the turbo before the EB too. With your proposed set then your will not if your twin are cooling properly no guessing.
Rear end temp gauge. (The truck not yours)
Exhaust temp gauge, intake air temp. Pre post fuel press? But I would prolly go with an oil press, but dont disable the warning light. (or install one alone with the gauge.) It will grab your attention quicker than a moving gauge needle.
