35"s with aftermarket wheels
I currently have Mickey Thompson Classic II's with Dick Cepek FC II's in 285/75/16. (Excellent tire by the way, just expensive) When my wheels are at full lock there is about 1 to 1-1/2 inches from the outside edge of the tire to the fender liner. I would like to put 35"s on but I don't know if they'll fit. I have a 2" leveling kit but stock control arms. I know that the best thing would be to buy aftermarket control arms to push my axle forward, but why buy them if the 35"s will fit without. So does anyone have the same setup or know if they will fit without the control arms?
Thanks
GO ARMY
Thanks
GO ARMY
Control arms or not, they won't fit without rubbing. At full lock, when the suspension compresses they'll hit the inner fender well.
My tires are only 1" closer to the fender that a 35 would be (1" larger radius) an I rub at full lock/compression. My axle is about 1.5" forward of stock, and I have 6" of lift.
I'd recommend at least 3" better yet 4" of lift to clear 35's.
A 285/75 is roughly a 33" tire....if you add 1" to the radius and you have 1-1.5" of clearance, that leaves you with 1/2" or less of clearance.....it'll rub.
roughstock
11-02-2013 01:48 PM
Nick & Kels 08
01-12-2011 06:14 PM
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
