12v newbie. these mods for a daily driver?
Old Nov 17, 2005 | 11:12 AM
Evildiesel's Avatar
I recently bought a 96 4x4 auto as a daily driver to replace my 89. I've been reading the 12v performance stuff for about a week now and was wondering if the following mods will work together to give me the power I'm looking for without any serious issues to the truck. I already have EGT, boost and Trans temp gauges as well as the Scotty 2 (with hole) from my '02. I want: 370 injectors, 3k GSK, #10 plate, 16.5* timing and 4 or 5" straight-pipe. The only thing Im not sure about is whether to change the turbine housing to a different size and what size that would be and if I need to modify the wastegate. I will be using the truck mostly to drive to work and occasionally pull a car trailer or similiar. When the auto finally goes I plan on converting to the NV4500. Smoke is not really an issue where I live and I rather enjoy it at WOT, but I'm not looking to leave a black trail under light acceleration. Ideas and suggestions appreciated.
Old Nov 17, 2005 | 11:29 AM
vssman's Avatar
370's and a #10 plate will be a little hot with just a stock HX35/12. Even worse when towing. You should consider a turbo upgrade. Also, the tranny isn't going to be friendly very long...
Old Nov 17, 2005 | 11:48 AM
plow's Avatar
get the #100 plate with the 370's {W.O.W}
Old Nov 17, 2005 | 12:36 PM
Evildiesel's Avatar
Thats why I considered a turbine housing change........Don't really care about the tranny....got a NV4500 lined up if/when it goes. Need to know how much boost Ill need to compensate for the above mods and roughly how much HP/TQ Ill get from them.
Old Nov 17, 2005 | 12:42 PM
TxDiesel007's Avatar
Oh yes
wonderful upgrade but its hard on your egts.... You will need a turbo if you drive it like a bat outta H E double hockey stick constantly....
Your mods are a good plan, the 10 is more towing friendly once again, but the 100 is all out awesome.. Its also more enjoyable with an auto trans. at times i wish i had one..... YES I DO.. but for towing you cannot beat the control of a manual.
Wastegate.. get a boost control elbow, and u can control that, i dont suggest that you go ahead and plug it up though, Make sure before you tweak with any of this stuff that the truck has the KDP killed and good gauges....
A light trail of smoke or heavy trail of smoke means that its just fuel that isnt being used. Smoke is power you can see, yet cannot use.. It only means ur turbo is inefficient at that level, you can always adjust that with plate positioning and starwheel as well....
For daily driving your mods seem great... I like your ideas.... and straight pipe, well it just sounds awesome, yet dont expect any performance gains out of it, i know i had a banks stinger exhaust (still do in back yard under a tarp in a crate) and it was ok, just muffled the sound too much, straight pipe is all in the same, plus the cooler sound.. A five inch will echo much louder in the pipe, and if you are overfueled with a five inch HOLY COW!!!
Tx
Old Nov 17, 2005 | 02:02 PM
Jambbii's Avatar
I had a similar setup ran fine on the street. I ran an 18.5cm housing with mine. Still got a little toasty if you held your foot in it. If your interested its for sale.
Old Nov 17, 2005 | 02:23 PM
WideOpenThrottl's Avatar
I would go with the stage 3 60mm housing and compressor kit from HTT, I just got done installing it, and with a bit more fuel, which u should have no problem with 370's, the spool up is the same, and it helps bring the temps down nicely. Its only about $200, its a good upgrade.
Tim
Old Nov 18, 2005 | 10:03 AM
Evildiesel's Avatar
Tim
Did you keep the same size turbine housing? How much boost are you producing with it?
Old Nov 18, 2005 | 11:02 AM
Jambbii's Avatar
You can keep the same size housing but it will still get hot depending on where your fuel plate is. I ran the 35/40 with the 18.5 and still would get warm. Boost I think the 35/45 is good untill the low 40s.
Old Nov 18, 2005 | 11:26 AM
Mcmopar's Avatar
I have a 4", AFE, 370's a banks "git kit" plate and it makes good power-see my sig. Temps are NOT an issue right now. I will be adding the number "4" plate after Thanksgiving!!
Old Nov 18, 2005 | 11:29 AM
No I have a wastegated 14cm housing, that I did some porting on and drilled out the divider for even wastegating for all 6 cylinders. Take a look at my pictures for drilling and porting.
Boost #'s are 40-41lbs, spool is quick, and Egt's don't get too hot(definatly cooler than the 35 with the 14cm exhaust housing), only get really high in the top of fifth, but all depends on if when u shift in previous gears rpm wise.
All in all, I like it, very good upgrade for the price.
Tim.
MrSuzuki
80
Aug 30, 2007 09:51 PM
ROUGHNECK
Aug 18, 2006 04:50 PM
bharring
Apr 29, 2004 02:55 PM
kingofdodge7131
Aug 31, 2003 12:20 PM
hellotbone
16
Nov 6, 2002 03:18 PM
