06 trans in a 96
Old Jun 22, 2007 | 09:05 AM
smokeyram's Avatar
06 trans in a 96
Other than the obvious advantage of being newer. If I were to pick up a almost new trans, other than having to upgrade computer.
- Is the 06 tranny any stronger?
- does the 06 lockup sooner, or help in any way?
I know most will say just to call Goerend or whoever, but id still like an answer.
Old Jun 22, 2007 | 10:37 AM
Need95-00CTD's Avatar
Good luck getting your computer to get it to work, the only thing I know that would allow it to work is a standalone trans controller, and your looking at serious money there.
Old Jun 22, 2007 | 12:34 PM
gmctd's Avatar
The '96 ECM controls TCC and overdrive, nothing else - the '06 is under complete ECM control, TCC, overdrive, governor pressure, shift ranges, everything - and that ECM is the common-rail fuel injection controller, instruments controller, ac interface, etc - no workee por '96, dude.
Just have your 47R beefed up with the hd components from the 48RE, get the 1200rpm stall TCC in larger single-disk, or triple disk, and yer good to go up to ~1000lbs torque.
And, BTW - talk to dave...............
Les Eid
Feb 13, 2008 09:22 AM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
