Trans temp gauge for manual trans?
Old Oct 29, 2005 | 03:02 AM
djgaston's Avatar
Is there any point in installing a transmission temperature gauge on a manual transmission? I guess monitoring any transmission temperature is important, but do manuals get hot like autos? Or do they only get hot if the clutch slips?
Old Oct 29, 2005 | 08:40 AM
MikeyB's Avatar
Unless you're towing really really heavy I don't think a temp gauge is necessary for the manuals.
MikeyB
Old Oct 29, 2005 | 09:00 AM
nickleinonen's Avatar
a manual trans will get hot under heavy loading [towing at full rated/overrated weight] but under normal driving/light towing, the trans won't get overly hot [lower temps than a rear differential] the manual transmission temp and clutch slipping have no relation in temprature [if anything, trans temp will go down as clutch slips as there will be less load transmitted through gears]
Old Oct 29, 2005 | 09:44 AM
Buffalo's Avatar
I called up a couple of the larger transmission shops (Blumenthal's,etc.) advertised in the TDR with the same question. Their opinion was that it couldn't hurt but, wasn't necessary. It's a big transmission with a lot of fluid in it.
Rather than a guage, I opted for a manual transmission filter which I purchased from Quad 4X4 (406-446-2427, www.quad4x4.com, e-mail dan@quad4x4.com). They were a little high in their price but, you got an installation video (which you don't really need. It's a simple installation.) & e-xtra filter & gaskets.
The same unit can be purchased through Geno's Garage at the TDR, cheaper. Don't know if you have to be a member, or not.
You may want to check with the DTR Performance Shop Store. I don't know if they sell the filters, or not.
The filter housing is mounted on the "passenger side" of the trans. & adds a bit more gear oil, also.
You seem concerned about the health & well-being of your manual trans. & I thought I'd offer you another alternative you may not have thought of. Hope this helps.
Joe F.(Buffalo)
Old Oct 30, 2005 | 02:21 PM
marty649's Avatar
You don't need to be a member of TDR to purchase from Geno's
Old Oct 30, 2005 | 03:18 PM
djgaston's Avatar
Thanks guys.
mar67655
Mar 21, 2009 05:35 AM
mar67655
Mar 17, 2009 07:57 PM
scsulfri
Dec 23, 2006 09:30 PM
scsulfri
Aug 16, 2006 10:38 PM
montemorris
Mar 16, 2005 12:53 PM
