01, 02 Edge Comp
Old Dec 16, 2004 | 11:29 PM
figure_9_pro's Avatar
01, 02 Edge Comp
What is the difference between the 2 boxes?
Can theY interchange between the 2 years???
(I have an 01 truck and a 02 comp)
Old Dec 17, 2004 | 06:53 AM
JBlock's Avatar
Apapter plug
One of the plugs need an aadapter was as I understand. Why not ask Edge Products
Old Dec 17, 2004 | 08:02 AM
RowJ's Avatar
Same Box! Different MAP plug in. Need an adaptor from EDGE...$38.00. Call them 888-360-3343.
Good Luck RJ
Old Dec 17, 2004 | 04:13 PM
Diesel-Dan's Avatar
RJohnson is right.....2002 has a rectangleular plug with a red slide lock and the 2001 has a flat plug with a tab snap type lock. You can get a hold of me...i have thoes plugs comming out of my ears...Bully Dog sends thoes adapter with all the 2001-02 boxes. I have had a run on alot of 01's so i have lots of the plugs! That is if you need em...
The only issue that you would run into is anything before 2001. 98.5-2000 used a triangular, round map plug that you cant interchange....or i havent seen a conversion harness for. ALSO from 98.5 - 99, the data link plug was differant. Other than that...the Comp box is the same...harness is differant. Just trivial info.......
Old Dec 17, 2004 | 04:24 PM
Kyle Graham's Avatar
Yah just a plug away from 120rwhp and 350lbft of torque you will need to upgrade that hy35 turbo if you haven't already you will achieve very high egt's due to that small compressor housing of 9cm with stock injectors just trying to help
Old Dec 17, 2004 | 04:29 PM
Diesel-Dan's Avatar
Kyle Graham
funny....haha... i am in Seattle untill Monday...just killing the day in the hotel room...haha....Nice state, first time here! Lots differant than Gainesville!
Old Dec 17, 2004 | 09:26 PM
Thanks for all the info!
This is the best place to get my questions answered!!!
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
